    Aug 2006
    Hi.
    I'm using a 3,0Ghz P4 with 512MB RAM and an integrated graphics card. Unfortunatly this is all I know about my system. I don't know what kind of RAM (guessing DDR) and I have no clue what type of mobo I have and so on.
    I encode WMV-streams from DVD-movies (m2v- and ac3-files) demuxed with DVDDecrypter. I use ProCoder 2.0 for this. I know encoding Xvid would be better but I can't change from WMV since the files are not for me.
    I encode one file with two bitrates (1500Kbit with 128Kbit audio) and (800Kbit with 128Kbit audio). Both 2-pass. I encode 24/7 all year round.
    The encoding takes forever (12 hours and more/movie).
    I would like to know what I can do to speed up the process.
    1, How much would it help if I got more RAM? Should I get 512 for a total of 1GB or should my total be even more?
    2, Would a new graphics card help? In that case are there any cards you recommend?
    3, I've been reading a bit about encoding cards. Should I get one of these? What do they do anyway? What exactly am I looking for? Is it an mpeg2-encoding card I want?
    Thanks heaps.
  2. More RAM won't help much. New graphics card won't help. Get a dual core CPU if your motherboard will take one.
    Aug 2006
    More RAM wont help much you said, but it would help right?
  4. Originally Posted by tominator
    It might cut a few seconds off your 12 hour encodes.
    One circumstance where it will make a bigger difference is if you are currently using a single stick of memory (single channel). Then switching to two sticks (dual channel) will make a significant difference. I don't remember how much difference it makes for WMV encoding, maybe 5 or 10 percent.
    Aug 2006
    Thanks again. Since Im not all into hardware I have to ask. Two memory sticks would make it dual channel regardless of my memory type? Or would I have to be using a specific type of memory?
  6. Depends on the Motherboard, All Motherboards do not support Dual Channel mode. Read the Manual.
    Answering your other question, No a MPEG2 encoding card will not help you encode WMVs as they are not MPEG2 format.
    This might be a silly question but have you tried other programs as a test to see if anything else is faster? WMM outputs WMV free in Xp. TMPGEnc Xpress can be set to output WMV Trialware.
    Also look through these .
    https://www.videohelp.com/tools?s=106#106
    Cheers
