Hi! Iam about to encode a XivD avi file in TMPGEnc. I see the XviD codec but i only got a sucky MP3 codec that encodes 56kbps, Iam sure that you understand what i mean. I have lame_enc.dll in my system32 dir, but it wont show up. I wont encode in PCM. Brrrr!
Results 1 to 11 of 11
I've never used TMPGEnc to encode to other formats than mpeg1/2 - VirtualDub is mostly used for this task around here.
This is needed for VirtualDub to use Lame - maybe the same applies to TMPGEnc?
/Mats -
Everything works fine, good quality etc. But there is no sound in the output file. Woot??
Probably because the source file audio is in a format TMPGEnc don't understand.
Convert it to wav, and use the wav as audio source when encoding.
Easiest way is to load the source in Goldwave, save as wav.
At this point, it'd help if you came out and told us what you have (source file) and what you intend to do with it (target format)
/Mats -
Like I said, the audio in the AVI is probably in a format TMPGEnc can't read.
Still no clue as to what your target format is tho, just that you want hard subs...
/Mats -
Look, i demuxed the audio from the avi file (wav), and I used that instead of the source audio. Then I use Lame MP3 som encode it. So, TMPGEnc is not reading the source audio. But I still dont got any sound in output. You said that i could do it that way, I´ve done that. Still no sound.Originally Posted by mats.hogberg
If you aren't doing any framerate change you could add back the audio from the original to the new encoded with virtualdubmod, streams->stream list.
Or add the subs and reencode with virtualdubmod, https://forum.videohelp.com/viewtopic.php?t=272736 -
Does the wav have sound after being demuxed out of the AVI?
For the 3rd time what is your target format?
/Mats
Lame MP3 Encoder on Vista x64
By edt in forum Newbie / General discussionsReplies: 23Last Post: 31st Jul 2014, 15:33 -
VirtualDub Video Compression h264 encoder Not Shown
By darkw1zard in forum EditingReplies: 2Last Post: 18th Oct 2011, 14:28 -
how to setup automkv to use lame mp3 encoder instead of fraunhofer
By deejay.2001 in forum Video ConversionReplies: 0Last Post: 1st Aug 2009, 06:42 -
Attaching an mp3 to a video without compression.
By Racoon29 in forum Newbie / General discussionsReplies: 13Last Post: 25th Jul 2009, 13:41 -
Can't Capture VHS Tapes+video Compression list Is Empty
By mikidream in forum Capturing and VCRReplies: 4Last Post: 21st Apr 2008, 11:27
