    Aug 2006
    so I've got adobe premiere and I'm using it for the first time. I need to ouput my video from the timeline to a DVD. I used the adobe mpeg encoder and got an output of an m2v and a wav file. Should I be looking for a program to mux them and then use the new file to make a DVD? Or not?
  2. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    1.) This thread is over 2 years old.
    2.) You should never have to mux before brining your video/audio into your DVD Authoring program. All such programs will work with separate files and if it doesn't then you need a new DVD Authoring program.
    - John "FulciLives" Coleman
    Aug 2006
    1. Thanks
    2. Aren't you in Romero town, not Fulci town?
  4. Member FulciLives's Avatar
    May 2003
    1. Thanks
    DAWN OF THE DEAD (the original which I f'ing hate I have to even say that now) is the best damn ZOMBIE film ever made.
    But I love a good poke in the eye as well
  5. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    I took the liberty of splitting this latter part off the original thread.
    /Mats
