Trying to update my driver I get a "Available Target is not found"
I don't know how to tell if the DVDs are PAL or not I have used DVD-RW 4x from Staples item # 6363134 and Philips DVD+R 16x that I got at RadioShack neither of these have ever worked. This is my first time doing trying to do this, so no it has never played a burned DVD. CDs work though if that helps lol.
Results 31 to 55 of 55
I'm also trying to play them on a Samsung m101 player but still no luck.
Why don't you copy an original DVD and burn to one of your discs, see if that works. If it works then it isn't your discs.
He's a liar and a murderer, and I say that with all due respect. -
Follow one of the guides here - https://www.videohelp.com/tools?tool=DVD_Shrink
Hey I got it to work with an original copy. Do you think there is something wrong with this iso that I have I have tried other ISOs and I still have the same problem though. This ISO has these files in it. "video_ts.info, video_ts.VOB, video_ts.BUP, VTS_01_0.INFO then a the rest are VOB with the last one being a BUP. Do I need to do something to these files?
Ok, mount your ISO using Daemon Tools, then open one of the VOB files from the ISO with Gspot, what does it say in the middle box on the right next to Frms/sec?
I'm sorry about that the files are all Video _ts and VTS_01_0 type files and 1 that has the title of the dvd which is a LAY file.
SORRY -
Delete the .LAY file(s) and re-burn it.
k I'll do that. By the way I really appreciate what you have and are still doin for me. Thanks a lot man.
I alsso have another iso though with the vob files but I can't see the box that you have on the pic there on my Gspot. When I go to open an Image on DVD Shink I get this error "Dvd Shrink encountered an error and cannot continue" "Failed to Open" I don't know why.
No, 2.52 Beta.
Right, so it's PAL. Does your DVD player play the PAL format?
hey but this other ISO I get this pop-up that say the Perimeter is Incorrect.
Well the manual says "Progressive Video Output with 3-2 Pulldown (for NTSC only)
PAL/NTSC Playback of any DVD or VCD (To play PAL movies you need a PAL TV or a Video converter.)
Plays any region DVD movie from the World from codes 1-6
Plays RCE/REA movies also
Plays DVD, V-CD, MP3, CD-R, CD-R/W, DVD-R, DVD-RW, DVD+R, DVD+RW
Region selection is automatic and manually adjustable by remote" -
Lets start from the beginning:
1.Where did you get the ISO/files from(ie DVD,download,etc)?
2.Use GSpot or AVICodec to see what the properties are,if 25fps/720x576 then you will have to convert to NTSC or get a multisystem DVD player.
3.After you author did you get a folder named VIDEO_TS and is it <4,460MB?
4.If DVDShrink chokes on the ISO/files then there's something wrong with the structure and you might try FixVTS. -
1-From an ISO
2-Yes it is
3-Yes it is 25fps/720x576 ------- what will be if it is in NTSC format?
What do you use to convert to NTSC? -
This indicates that your player outputs a PAL signal which your TV doesn't like.Originally Posted by Platinum911911"Art is making something out of nothing and selling it." - Frank Zappa
Right, your DVD player plays PAL, so we can rule that out. Have you actually tried deleting the .LAY file(s) and burning it again? Do you have any friends that have a PAL compatible tv? Take your disc to their house and try it.
My only guess is that I saw Optodisc media somewhere in there. My Pioneer literally pukes when I put an Optodisc DVD blank in it. Very, very infrequently do I get a successful burn with one. Try some Ty media instead, better media.
As I said earlier, "according to the Sony eSupport Knowledge Base, your dvd player can't play PAL". If you go to this page at sony.com, it says:
If you download the Operating Instructions for the DVP-NS725P, on page 6 it says:SonyŽ DVD players and recorders sold in the United States support the NTSC video format standard and region 1 discs. They are not able to play or record discs in the PAL or SECAM video format standard or any other region codes.Also, the player cannot play the following discs:...A disk recorded in a color system other than NTSC, such as PAL...
How to Extract an ISO Image without burning to dvd?
By skorpinok in forum ComputerReplies: 8Last Post: 26th Sep 2018, 03:07 -
I need a DVD movie supplier, PLZ!
By caesarhawy in forum Off topicReplies: 0Last Post: 17th Mar 2009, 02:54 -
HELP PLZ! is it possible to convert and ISO image to another file type...
By carapalida in forum Video ConversionReplies: 13Last Post: 7th Apr 2008, 18:58 -
ISO to DVD burning?
By sufcdan in forum MacReplies: 8Last Post: 22nd Feb 2008, 14:42 -
Burning ISO file to DVD
By hcs in forum DVD RippingReplies: 5Last Post: 2nd Feb 2008, 14:34
