Hey guys I have a problem I have a movie ISO and I want to burn it on a dvd to play it on my dvd player in the living room. So far I have tried to do it about 15 times and have waisted about 15 dvds. I have follewed a lot of steps that I have found on burning ISOs, but still I have a problem. My DVD player does not read the burned dvd for some reason. When I tried to burn it with Nero, it fails burning in the end and it says something like "Could not put the finish" or something like that. I really need some help here guys I'm goin nuts over this, I can't burn a movie no matter what. PLZ Help.
Results 1 to 30 of 55
Make sure you have the latest firmware for your writer: www.rpc1.org
...and make sure the compilation is <4,460MB. -
it is a Video_ts with all these other video_ts.BUP and vts_02_0.BUP files in it
how do i get the right firmware at that website. I have a Pioneer DVD-RW DVR-108
Can any1 actually help me here instead of giving me dead end ways of doing it?
Click on "Download Firmware" and look for you manufacturer/burner type, then find your model number? Took me about a minute.Originally Posted by Platinum911911
Jim -
yeah but there is nothing for the Pioneer DVD-RW DVR-108. What do I do?
I found some fimrmware but when I trie to install I get a "Available target is not found" any ideas?
This isn't your model?:
http://forum.rpc1.org/dl_firmware.php?download_id=1898
You could also check Pioneer's website for firmware updates - I know Plextor has all the updates for my DVD burner.
Also, follwo the other suggestions: check the size of what you are burning as MOVIEGEEK suggested, and try another burning app, like ImgBurn - I've never had any issues using it.
Good luck,
Jim -
do u know how to install this? I get this message "Available target is not found"
now i"m getting a "It is unnecessary to update" does that mean the Firmware is good?
Platinum911911,
It sounds like your firmware is up to date, so that's not the problem.
The surest way to see what's going wrong is if you'll post a burn log. Since you mentioned Nero, edit the log to remove your serial number before posting it. -
THIS IS THE LOG FROM NERO
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 11/2/2004 1:54:32 PM
NT-SPTI used
Nero Version: 7.2.3.3
Internal Version: 7, 2, 3, 3
Recorder: <PIONEER DVD-RW DVR-108> Version: 1.10 - HA 1 TA 0 - 7.2.3.3
Adapter driver: <IDE> HA 1
Drive buffer : 2000kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <YU3415Q KSP677F >Version: 1.0 - HA 1 TA 2 - 7.2.3.3
Adapter driver: <SCSI> HA 1
=== Scsi-Device-Map ===
CdRomPeripheral : PIONEER DVD-RW DVR-108 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : LITE-ON LTR-16101B atapi Port 0 ID 1 DMA: On
DiskPeripheral : ST3200822AS iaStor Port 1 ID 0 DMA: On
CdRomPeripheral : YU3415Q KSP677F 1.0 dtscsi Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
PIONEER DVD-RW DVR-108 D: CDRom0
YU3415Q KSP677F I: CDRom2
LITE-ON LTR-16101B J: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 1023MB (1047908kB)
Free physical memory: 453MB (464028kB)
Memory in use : 55 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
20.8.2006
UDF/ISO compilation
4:27:47 PM #1 Phase 112 File dlgbrnst.cpp, Line 1730
DVD-Video files reallocation started
4:27:47 PM #2 Phase 114 File dlgbrnst.cpp, Line 1730
DVD-Video files reallocation completed (no file modified)
4:27:47 PM #3 Text 0 File Isodoc.cpp, Line 6427
UDF document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
UDF Mode : UDF/ISO bridge
UDF Options : automatic
UDF Revision : 1.02
UDF Partition Type : physical
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : FALSE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
4:27:47 PM #4 Phase 111 File dlgbrnst.cpp, Line 1730
DVD-Video files sorted
4:27:48 PM #5 Text 0 File ThreadedTransfer.cpp, Line 531
ReadBuffer-Pipe got 81920KB of Memory
4:27:48 PM #6 Text 0 File Reader.cpp, Line 124
Reader running
4:27:48 PM #7 Text 0 File Writer.cpp, Line 113
Writer D: PIONEER DVD-RW DVR-108 running
4:27:48 PM #8 ISO9660GEN -11 File Geniso.cpp, Line 3312
First writeable address = 0 (0x00000000)
4:27:48 PM #9 ISO9660GEN -11 File Geniso.cpp, Line 3312
4:27:48 PM #10 Text 0 File Burncd.cpp, Line 3400
Turn on Disc-At-Once, using DVD media
4:27:48 PM #11 Text 0 File DlgWaitCD.cpp, Line 290
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 1388239 (308:29.64, 2711MB)
4:27:48 PM #12 Text 0 File DlgWaitCD.cpp, Line 302
Write in overburning mode: NO (enabled: CD)
4:27:48 PM #13 Text 0 File DlgWaitCD.cpp, Line 2733
Recorder: PIONEER DVD-RW DVR-108, Media type: DVD-RW
Disc Manufacturer: OPTODI - SCW004
Disc Application Code: 2, Disc Physical Code: 214
4:27:48 PM #14 Text 0 File DlgWaitCD.cpp, Line 474
>>> Protocol of DlgWaitCD activities: <<<
4:27:48 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 847
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 1388240 (1388240) = #1388240/308:29.65
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1388240 blocks [D: PIONEER DVD-RW DVR-108]
4:27:49 PM #16 Text 0 File ThreadedTransferInterface.cpp, Line 1059
Prepare recorder [D: PIONEER DVD-RW DVR-108] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 2843115520, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
1388240 | lead-out | 1 | 0x41 | 0x00
4:27:49 PM #17 Text 0 File SCSIPassThrough.cpp, Line 39
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
4:27:49 PM #18 Phase 24 File dlgbrnst.cpp, Line 1730
Caching of files started
4:27:49 PM #19 Text 0 File Burncd.cpp, Line 4231
Cache writing successful.
4:27:49 PM #20 Phase 25 File dlgbrnst.cpp, Line 1730
Caching of files completed
4:27:49 PM #21 Phase 36 File dlgbrnst.cpp, Line 1730
Burn process started at 4x (5,540 KB/s)
4:27:49 PM #22 Text 0 File ThreadedTransferInterface.cpp, Line 2707
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
4:27:49 PM #23 Text 0 File DVDR.cpp, Line 2877
Recording mode: Sequential Recording Mode
4:27:49 PM #24 Text 0 File DVDR.cpp, Line 3033
Start write address at LBA 0
DVD high compatibility mode: Yes
4:27:49 PM #25 SPTI -1066 File SCSIPassThrough.cpp, Line 291
D: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAC 00 00 00 00 00 00 00 01 00 00 00
Sense Area: 0x70 00 05 00 00 00 00 0E 00 00 00 00 24
Buffer x05457c00: Len x1008
4:27:49 PM #26 Text 0 File Cdrdrv.cpp, Line 8995
---- DVD Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-RW (3), Extended Part Version: 1.2 (18)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 20 10 00 00 00 00 00 - 00 00 03 12 00 00 00 00 ................
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
4:27:51 PM #27 Text 0 File Cdrdrv.cpp, Line 1224
16:27:51.181 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:28:30 PM #28 Text 0 File Cdrdrv.cpp, Line 1224
16:28:30.519 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:28:31 PM #29 Text 0 File Cdrdrv.cpp, Line 1224
16:28:31.675 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:28:35 PM #30 Text 0 File Cdrdrv.cpp, Line 1224
16:28:35.472 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:28:35 PM #31 Text 0 File Cdrdrv.cpp, Line 1224
16:28:35.487 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:28:39 PM #32 Text 0 File Cdrdrv.cpp, Line 1224
16:28:39.580 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:28:39 PM #33 Text 0 File Cdrdrv.cpp, Line 1224
16:28:39.971 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:28:40 PM #34 Text 0 File Cdrdrv.cpp, Line 1224
16:28:40.002 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:28:40 PM #35 Text 0 File Cdrdrv.cpp, Line 1224
16:28:40.034 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:28:41 PM #36 Text 0 File Cdrdrv.cpp, Line 1224
16:28:41.877 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:28:43 PM #37 Text 0 File Cdrdrv.cpp, Line 1224
16:28:43.158 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:28:43 PM #38 Text 0 File Cdrdrv.cpp, Line 1224
16:28:43.283 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:28:43 PM #39 Text 0 File Cdrdrv.cpp, Line 1224
16:28:43.299 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:28:43 PM #40 Text 0 File Cdrdrv.cpp, Line 1224
16:28:43.346 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:28:43 PM #41 Text 0 File Cdrdrv.cpp, Line 1224
4:28:43 PM #42 Text 0 File Cdrdrv.cpp, Line 1224
16:28:43.377 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:28:44 PM #43 Text 0 File Cdrdrv.cpp, Line 1224
16:28:44.314 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:28:44 PM #44 Text 0 File Cdrdrv.cpp, Line 1224
4:28:49 PM #45 Text 0 File Cdrdrv.cpp, Line 1224
16:28:49.892 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:28:49 PM #46 Text 0 File Cdrdrv.cpp, Line 1224
16:28:49.938 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:28:49 PM #47 Text 0 File Cdrdrv.cpp, Line 1224
4:28:49 PM #48 Text 0 File Cdrdrv.cpp, Line 1224
16:28:49.970 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:28:50 PM #49 Text 0 File Cdrdrv.cpp, Line 1224
16:28:50.032 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:28:50 PM #50 Text 0 File Cdrdrv.cpp, Line 1224
4:29:00 PM #51 Text 0 File Cdrdrv.cpp, Line 1224
16:29:00.140 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:29:00 PM #52 Text 0 File Cdrdrv.cpp, Line 1224
16:29:00.156 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:29:00 PM #53 Text 0 File Cdrdrv.cpp, Line 1224
16:29:00.390 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:29:02 PM #54 Text 0 File Cdrdrv.cpp, Line 1224
16:29:02.702 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:29:02 PM #55 Text 0 File Cdrdrv.cpp, Line 1224
16:29:02.780 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:29:02 PM #56 Text 0 File Cdrdrv.cpp, Line 1224
16:29:02.796 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:29:06 PM #57 Text 0 File Cdrdrv.cpp, Line 1224
16:29:06.686 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:29:06 PM #58 Text 0 File Cdrdrv.cpp, Line 1224
16:29:06.749 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:29:06 PM #59 Text 0 File Cdrdrv.cpp, Line 1224
4:29:07 PM #60 Text 0 File Cdrdrv.cpp, Line 1224
16:29:07.342 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:29:13 PM #61 Text 0 File Cdrdrv.cpp, Line 1224
16:29:13.326 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:29:20 PM #62 Text 0 File Cdrdrv.cpp, Line 1224
16:29:20.762 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:29:20 PM #63 Text 0 File Cdrdrv.cpp, Line 1224
16:29:20.809 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:29:31 PM #64 Text 0 File Cdrdrv.cpp, Line 1224
16:29:31.261 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:29:37 PM #65 Text 0 File Cdrdrv.cpp, Line 1224
16:29:37.385 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:29:37 PM #66 Text 0 File Cdrdrv.cpp, Line 1224
16:29:37.463 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:29:37 PM #67 Text 0 File Cdrdrv.cpp, Line 1224
16:29:37.526 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:29:37 PM #68 Text 0 File Cdrdrv.cpp, Line 1224
4:29:37 PM #69 Text 0 File Cdrdrv.cpp, Line 1224
16:29:37.541 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:29:37 PM #70 Text 0 File Cdrdrv.cpp, Line 1224
16:29:37.573 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:29:45 PM #71 Text 0 File Cdrdrv.cpp, Line 1224
16:29:45.056 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:29:48 PM #72 Text 0 File Cdrdrv.cpp, Line 1224
16:29:48.024 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:29:49 PM #73 Text 0 File Cdrdrv.cpp, Line 1224
16:29:49.415 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:29:49 PM #74 Text 0 File Cdrdrv.cpp, Line 1224
16:29:49.446 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:29:49 PM #75 Text 0 File Cdrdrv.cpp, Line 1224
16:29:49.477 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:29:49 PM #76 Text 0 File Cdrdrv.cpp, Line 1224
16:29:49.493 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:29:52 PM #77 Text 0 File Cdrdrv.cpp, Line 1224
16:29:52.039 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:29:52 PM #78 Text 0 File Cdrdrv.cpp, Line 1224
16:29:52.118 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:29:52 PM #79 Text 0 File Cdrdrv.cpp, Line 1224
16:29:52.133 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:29:52 PM #80 Text 0 File Cdrdrv.cpp, Line 1224
16:29:52.211 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:29:55 PM #81 Text 0 File Cdrdrv.cpp, Line 1224
16:29:55.508 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:29:55 PM #82 Text 0 File Cdrdrv.cpp, Line 1224
4:29:56 PM #83 Text 0 File Cdrdrv.cpp, Line 1224
16:29:56.133 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:29:56 PM #84 Text 0 File Cdrdrv.cpp, Line 1224
16:29:56.148 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:30:04 PM #85 Text 0 File Cdrdrv.cpp, Line 1224
16:30:04.163 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:30:05 PM #86 Text 0 File Cdrdrv.cpp, Line 1224
16:30:05.022 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:30:05 PM #87 Text 0 File Cdrdrv.cpp, Line 1224
16:30:05.069 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:30:05 PM #88 Text 0 File Cdrdrv.cpp, Line 1224
16:30:05.085 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:30:08 PM #89 Text 0 File Cdrdrv.cpp, Line 1224
16:30:08.069 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:30:08 PM #90 Text 0 File Cdrdrv.cpp, Line 1224
4:30:10 PM #91 Text 0 File Cdrdrv.cpp, Line 1224
16:30:10.146 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:30:10 PM #92 Text 0 File Cdrdrv.cpp, Line 1224
16:30:10.209 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:30:10 PM #93 Text 0 File Cdrdrv.cpp, Line 1224
16:30:10.225 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:30:12 PM #94 Text 0 File Cdrdrv.cpp, Line 1224
16:30:12.490 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:30:12 PM #95 Text 0 File Cdrdrv.cpp, Line 1224
16:30:12.505 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:30:12 PM #96 Text 0 File Cdrdrv.cpp, Line 1224
16:30:12.552 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:30:21 PM #97 Text 0 File Cdrdrv.cpp, Line 1224
16:30:21.207 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:30:21 PM #98 Text 0 File Cdrdrv.cpp, Line 1224
16:30:21.239 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:30:21 PM #99 Text 0 File Cdrdrv.cpp, Line 1224
16:30:21.286 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:30:25 PM #100 Text 0 File Cdrdrv.cpp, Line 1224
16:30:25.129 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:30:30 PM #101 Text 0 File Cdrdrv.cpp, Line 1224
16:30:30.487 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:30:30 PM #102 Text 0 File Cdrdrv.cpp, Line 1224
16:30:30.503 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:30:37 PM #103 Text 0 File Cdrdrv.cpp, Line 1224
16:30:37.486 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:30:37 PM #104 Text 0 File Cdrdrv.cpp, Line 1224
16:30:37.533 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:30:37 PM #105 Text 0 File Cdrdrv.cpp, Line 1224
16:30:37.674 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:30:37 PM #106 Text 0 File Cdrdrv.cpp, Line 1224
4:30:38 PM #107 Text 0 File Cdrdrv.cpp, Line 1224
16:30:38.221 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:30:40 PM #108 Text 0 File Cdrdrv.cpp, Line 1224
16:30:40.611 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:30:45 PM #109 Text 0 File Cdrdrv.cpp, Line 1224
16:30:45.251 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:30:48 PM #110 Text 0 File Cdrdrv.cpp, Line 1224
16:30:48.032 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:30:48 PM #111 Text 0 File Cdrdrv.cpp, Line 1224
16:30:48.048 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:30:49 PM #112 Text 0 File Cdrdrv.cpp, Line 1224
16:30:49.938 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:30:51 PM #113 Text 0 File Cdrdrv.cpp, Line 1224
16:30:51.406 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:30:52 PM #114 Text 0 File Cdrdrv.cpp, Line 1224
16:30:52.906 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:30:54 PM #115 Text 0 File Cdrdrv.cpp, Line 1224
16:30:54.094 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:30:54 PM #116 Text 0 File Cdrdrv.cpp, Line 1224
4:30:56 PM #117 Text 0 File Cdrdrv.cpp, Line 1224
16:30:56.484 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:30:56 PM #118 Text 0 File Cdrdrv.cpp, Line 1224
4:30:56 PM #119 Text 0 File Cdrdrv.cpp, Line 1224
16:30:56.515 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:30:57 PM #120 Text 0 File Cdrdrv.cpp, Line 1224
16:30:57.374 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:31:06 PM #121 Text 0 File Cdrdrv.cpp, Line 1224
16:31:06.889 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:31:06 PM #122 Text 0 File Cdrdrv.cpp, Line 1224
16:31:06.904 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:31:06 PM #123 Text 0 File Cdrdrv.cpp, Line 1224
16:31:06.936 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:31:08 PM #124 Text 0 File Cdrdrv.cpp, Line 1224
16:31:08.060 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:31:08 PM #125 Text 0 File Cdrdrv.cpp, Line 1224
16:31:08.076 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:31:08 PM #126 Text 0 File Cdrdrv.cpp, Line 1224
16:31:08.170 - D: PIONEER DVD-RW DVR-108 : Queue again later
4:37:03 PM #127 Text 0 File WriterStatus.cpp, Line 116
<D: PIONEER DVD-RW DVR-108> start writing Lead-Out at LBA 1388240 (152ED0h), length 0 blocks
4:37:03 PM #128 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
4:37:03 PM #129 Text 0 File DVDR.cpp, Line 3273
EndDAO: Last written address was 1388239
4:37:03 PM #130 Phase 181 File dlgbrnst.cpp, Line 1730
Writing lead-out...
4:37:03 PM #131 Text 0 File DVDR.cpp, Line 3306
Estimated time for 30mm Borders: 0min 00sec
4:37:34 PM #132 Phase 37 File dlgbrnst.cpp, Line 1730
Burn process completed successfully at 4x (5,540 KB/s)
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 10/28/2005 6:00:00 AM
File 'WNASPINT.DLL': Ver=V1.18, size=57344 bytes, created 11/2/2002 9:53:04 AM
File 'Drivers\PXHELP20.SYS': Ver=3.00.10a, size=46080 bytes, created 10/28/2005 6:00:00 AM (Prassi/Veritas driver for win 2K)
File 'Drivers\scsiport.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=96256 bytes, created 8/10/2004 8:00:00 AM (Adapter driver for src)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) -
Well, I know nothing about Nero, but from what I can see, it burned successfully.
Take a look at:
From what I gather, the last address to be written shows you how long the file is to be burned.
Then look at:
Looks like it write the whole file to the disc.
And, finally:
You can look at the disc to see if it did in fact burn - since your file is smaller than the total capacity of the disc you should see a distinct difference in the burned and un-burned areas.
Have you tried playing this DVD?
Again, it might be worthwhile to download ImgBurn and try it. See if it produces different results.
Jim -
Well, if the DVD will play on the computer, then it burned fine. Problem may lie with the DVD player. Will it play the DVD media you're using? I can't tell for sure, but it looks like you are using DVD-RW discs? Will your DVD player play DVD-RW discs? The owners manual should say, one way or another.
Jim -
I guess the only other thing to try is a different brand of media - it would seem that the player doesn't like whatever media you are currently using.
You burned succesfully, and it plays fine in the PC. Sounds like you just need to find media your player likes.
Have a look at info about your player in the "DVD Players" section to the left <<<<<. Read the comments, and see if anyone else has reported issues with your media (shrug). That's about all I have at this point.
Jim -
This was asked early (by Baldrick) in the thread but I never saw an answer, unless I missed it - is the ISO file a proper DVD format? Look at one of your burned DVDs and see if you have a VIDEO_TS folder with vob,ifo and bup files and an AUDIO_TS folder that is empty. That is what you will get burned onto the DVD if the ISO is holding the proper files to make a DVD. If you do it must be that your DVD player doesn't like your media at all.
Steve W. -
Do you guys know what VR MODE means? My DVD player Manual says that it will not play DVD-RWs in VR Mode. Could that be a problem?
I meant the original files that are contained in the ISO, were they created on a standalone DVD recorder?
He's a liar and a murderer, and I say that with all due respect. -
Platinum911911,
Sorry it took so long to get back to you.
Starting with the easiest possible cause first, according to the Sony eSupport Knowledge Base, your dvd player can't play PAL, so if the dvd you're trying to use is PAL, then you've found the cause of the problem, and you don't have to read any further.
Taking a look at your burn log, I see:
It looks like your computer is doing a whole lot of something that's not burning. It might a good idea to ease off on doing other things on the computer for the few minutes it takes to do a burn.Physical memory : 1023MB (1047908kB)
Atapi error code 052400 could be caused by anything, but at the top of the list of possible causes is other programs running at the same time as the burn.Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
You should try shutting down everything but the burning program and try a test burn. Since you're using a RW, all it will cost you is a little time to check it out.
You can get the latest official firmware version for the DVR-108 (1.20B) by clicking here. Your burn log shows you currently are using version 1.10. It looks like the firmware updates since 1.10 have been to add 8x burning for selected media, so it may not help with your current problem (the burn log shows you're burning at 4x).
Just to make sure, has your dvd player ever played a dvd-r(w) that you've burned?
How to Extract an ISO Image without burning to dvd?
By skorpinok in forum ComputerReplies: 8Last Post: 26th Sep 2018, 03:07 -
I need a DVD movie supplier, PLZ!
By caesarhawy in forum Off topicReplies: 0Last Post: 17th Mar 2009, 02:54 -
HELP PLZ! is it possible to convert and ISO image to another file type...
By carapalida in forum Video ConversionReplies: 13Last Post: 7th Apr 2008, 18:58 -
ISO to DVD burning?
By sufcdan in forum MacReplies: 8Last Post: 22nd Feb 2008, 14:42 -
Burning ISO file to DVD
By hcs in forum DVD RippingReplies: 5Last Post: 2nd Feb 2008, 14:34
