  1. I've included HDTV/DVB input to avi.NET, it's not released yet as I haven't tested it enough. If anyone here wants to test and give some feedback I'd be most grateful.
    It will accept HDTV MPEG files and .ts files. If there's more than one set of PID's it will allow you to choose. I'm not so much worried about the conversion aspects just yet but more on whether they load in OK e.t.c.
    Due to the massive size of some of these files the preview window will stutter.
    It's only an update to v2.1.7.0
    http://www.dvduk.pwp.blueyonder.co.uk/__files/avi.NET_BETA_Update.zip
    The few ts trailers I had loaded fine.
    Test encoding now.
    and if you are going to use the you need to uncheck the "disable bbcode in this post" when posting.
    USA
    It sounds interesting. I'll see if I can give it a try tonight.
    And thanks for the great program.
    Worked fine to encode to DivX also, both from 1280x720p and 1920x1080i ts sources.
    I don't have any ts with multiple audio tracks so I can't test it.
  5. That's great news, thanks for testing and thanks for the 'heads-up' on the tags
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    i would like to use higher resolution like 1280x720...
  7. avi.NET only makes AVI's that are standalone compatible, hence I cannot make an output file of that size, sorry.
