  1. Friends!
    After ripping a DVD, a got a AVI file. Bot this AVi file has no sound. Why?
    p.s. I used apollo nr1 DVD ripper
    Apr 2002
    Oskeeweewee Ontario
    Give us more information man!!!
    I don't know of any ripping program that rips out an .AVI from a DVD, since......well.....DVD's don't contain .AVI's..
    But perhaps your preffered ripper somehow rips and uncompresses..
    Load the file into VirtualDub, and go to File>File information, and tell us the audio specs..
    Use Autogk or FairUse Wizard instead of apollo nr1 dvd ripper...
  4. Originally Posted by Baldrick
    Thanks man! I tried one of the softs that you suggested me. AutoGK!
    You know what is happening now? AutoGK created a avi file. The problem is that in my PC, i can have the sound of the avi-movie only in VLC player and divx palyer. With real player or WM player, jetaudio player etc, there is no sound. I do not know why?
    With this file a created a DVD, burning them with DVD creater soft. In my DVd player there is no sound! Why?
    Thanks a lot...
  5. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    What information about the AVI do you see in VLC if you select "Stream and Media Info" from the View menu (or press Ctrl-I), and pick the "Advanced information" tab in the "Stream and Media Info" window that comes up? It should mention the codecs used in the video. If possible, copy the information here.
    Alternatively, you can get information on the AVI with programs like GSpot, AVI2Clipboard, etc. But to be able to know why you're not hearing any sound with other players or your DVD player, we have to know a little more about the AVI.
  6. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Okay, if i'm reading this right....
    You are ripping from a dvd to get an avi...
    Then you are taking that avi and converting it back to a dvd to play on your dvd player ?
  7. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Could be because of the audio the DVD originally had. Load the AVI into GSpot and use https://forum.videohelp.com/viewtopic.php?t=271697 to upload a screenshot.
    If in doubt, Google it.
