Hi
I posted here yesterday for the first time. This was my initial post:
I hope this is the right place to ask this question.
I'm having a problem with which type of DVD to buy to record. I have a Sharp DV-SR45UC and I've been using Sony DVD-RW with no problems but last week I bought Sony DVD-R and they don't work with my recorder. My manual states that the recorder won't work with DVD-R General Ver 2.0/8x and the Sony DVD-R is Ver 2.1/16x. I thought because I was using Sony DVD-RW that the DVD-R version would work without a problem.
Can anyone help or direct me to someplace that can help?
Thanks in advance if anyone answers this message.
This was the response I recv'd.
Take a look to the left under 'DVD Recorders' and you should find a similar model. Check the comments there and you should get an idea which discs some members use.
It sounds like that model will only work with 4X media. It's getting a little hard to find, but if you can't locate it locally, there is www.supermediastore.com, www.meritline.com, and www.rima.com, to mention a few that should carry them online.
lordsmurf's site listed above has a lot of good information on DVD media that may help also.
BTW, you should start a new thread when you question is not directly related to the original post.
And welcome to our forums.
Moving this thread to the Media forum.
This was very helpful and I appreciate the welcome and the guidance about posting as well as being directed to the right location etc.
Today I called Sharp hoping the would tell me what I was told here (and what I found in DVD Recorder section). Instead I was told that my recorder could possibly work with 16x discs and that speed shouldn't be an issue when buying the discs. It's all a matter of trial and error. Is this true? The person I spoke to mentioned Maxell, Verbatim and Fuji as brands I should try, but said that the speed on the disc shouldn't be an issue.
I guess my question is, if anyone has this DVD recorder, what DVD-R do you use? And, should I consider the speed on the disc when buying it, or is it not important?
Thanks in advance,
Sara
Results 1 to 1 of 1
Sharp lc-40lb700x
By Margot in forum Newbie / General discussionsReplies: 0Last Post: 8th Jun 2010, 05:16 -
Sharp DV-RW370
By alduz in forum DVD & Blu-ray RecordersReplies: 0Last Post: 11th Mar 2010, 02:24 -
Can't interface Panasonic DMR-15 DVD Recorder with Sharp LC-42D65U HDTV
By fideauxdon in forum DVD & Blu-ray RecordersReplies: 3Last Post: 2nd Mar 2010, 15:15 -
sharp dv-sv90
By tatusik in forum DVD & Blu-ray PlayersReplies: 1Last Post: 3rd Mar 2008, 11:02 -
Component overly sharp?
By NES_Master in forum DVD & Blu-ray PlayersReplies: 4Last Post: 1st Oct 2007, 01:15
