I use WinDV to capture my videos from the camcorder.I am very satisfied with it but only thing what's bothering me,each time I capture something,the captured file is not as 1 big file but more small files.I tried to look in the settings but didnt find anythingIt's possible to change it??
jak se máte? Mate prani?
Click the config button. Change "Max AVI size (frames)" to 1000000. This will allow you to record a very long time in one file. Make sure "every nth frame" is "1", so it records all frames.
Dám si jedno pivo prosím.
Also set discontinuity to 0 if you don't want it broken up by timecodes.
Buy My Books -
Vidim Texas,ja jsem na Floride.
Pivecko bych si ted zrovna dal.
Should I use WinDV?
By tygger in forum Capturing and VCRReplies: 19Last Post: 6th Jan 2012, 18:23 -
Windv to harddrive
By runnernorth in forum Capturing and VCRReplies: 3Last Post: 12th Jan 2010, 05:36 -
How to configure windv?
By BonnieW88 in forum Capturing and VCRReplies: 3Last Post: 13th Sep 2009, 09:30 -
WinDV
By kippard in forum Capturing and VCRReplies: 3Last Post: 8th Apr 2008, 00:43 -
Error with WinDV ?
By Zhuge Liang in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 13th Jul 2007, 03:47
