I've been trying to burn rm files into one dvd, but it was so troublesome converting them. I've searched the net, there's rumor that there's a rmvb plugin for nero so that you can burn rmvb files straight to dvd with nero. I don't know the plugin's name, and I couldn't find it in the net. Is that true?
Results 1 to 9 of 9
A quick google produced a lot of links claiming Real Alternative will allow tmpgenc to encode rmvb files. You can find Real Alternative in the Tools section here.
Read my blog here.
But then: encode rmvb (which usually is low quality) to DVD with Nero (which is a low quality encoder) - Why?
/Mats -
Make more sense than using a high quality encoder if you ask me. RV9 EHQ is actually capable of decent quality though.
I've tried those programs you guys mentioned, waste too much time converting. I got those codecs installed, but Nero just couldn't directly burn rm into DVD. And you guys still haven't answer my question. "Does nero has a plugin that burns rm files?"
Have you tried searching for a 'Nero plugin pack'? I doubt either Nero or Real would approve of something like that, though.
I've only seen one for converting RealAudio formats. Nothing for RM/RMVB. To be honest, since it's a proprietary format, your best bet probably is indeed to use the other programs mentioned to convert. You can always have the programs convert the files directly to DVD-spec MPEG-2, if you're worried about the conversions.
rmvb help
By aimbdd in forum ffmpegX general discussionReplies: 4Last Post: 7th Aug 2008, 19:22 -
RMVB
By magius in forum AudioReplies: 4Last Post: 7th Jan 2008, 09:26 -
Nero Blu-Ray/HD plugin problems
By lostinlodos in forum Authoring (DVD)Replies: 0Last Post: 27th Jul 2007, 19:01 -
Where can I find Nero Showtime plugin for ATI Remote Wonder?
By fk in forum Software PlayingReplies: 0Last Post: 13th Jul 2007, 02:53 -
Nero FLAC plugin doens't work
By happydog500 in forum AudioReplies: 0Last Post: 4th Jun 2007, 13:07
