hi, i have been using SUPER to convert my .avi files etc. to
.vob dvd complaint format for a long time now and today i converted a bunch of .avi file just like always and then i loaded them up into the dvd maker program(dvd workshop) and dvd workshop started converting them which it should'nt since they are .vob files already, so i looked at the files properties and it was in PAL format instead of NTSC, so i know why dvd workshop was converting it i just don't know why all of a sudden SUPER is converting the files in PAL format, my settings for SUPER are:
Output Container: vob dvd complaint
Output Codec: Mpeg 2
Audio Codec: AC3
Video Scale:Size: 704x576
Aspect: 4:3
Bitrate kbps: 5760
Options: Hi quality
Sampling frequency: 48000
Channels: 2
Bitratekbps: 384
Dvd language select; default
I always use the above setting and i havent added anythiong else to the computer in months software etc. I have the latest version of SUPER v.2006 build 19.
Any Help is welcomed , it's just so strange i donot see any visible way to change from NTSC to Pal format in the program at all. and why in the world is SUPER converting files to PAL format all of a sudden.......................................
I see everything listed there except the framerate.
704 X 576 is a PAL framesize. When I put a PAL (25fps) in SUPER, it gives me the choices of 23.98, 29.97, 25 and 30 fps. And also both PAL and NTSC frame sizes, or 'Video Scale Size' as it calls them.
You might want to check your framerate and framesize before encoding. There's a problem there somewhere. -
WOOHOO! that was it, i swear u learn something new everyday! Thanx soooo much
problem converting to mp4 with super
By cduval04 in forum Video ConversionReplies: 2Last Post: 16th Dec 2008, 11:42 -
Using super mp4 to DV(avi) only pal ?
By doggyjumper in forum Video ConversionReplies: 4Last Post: 13th Sep 2008, 18:48 -
Problem with SUPER when converting RM to any format...
By hzgg2 in forum Video ConversionReplies: 1Last Post: 22nd Apr 2008, 13:32 -
Converting with SUPER for PSP
By Nitro89 in forum Video ConversionReplies: 10Last Post: 3rd Mar 2008, 13:37 -
Converting PAL video to NTSC through SUPER
By DJL82 in forum Video ConversionReplies: 14Last Post: 3rd Jan 2008, 04:23
