Hi
I have bunch of svcds which i want to put on a dvd with fancy menus so iam try to use dvdlab pro. when the dvd is completed. i noticed the subtitles are half off screen at the bottom.
why would this be happning. do i have to make any settings when iam adding subtitles in dvdlab?.
Is the video hardsubbed? If it is, do a search on overscan.
If not, use DVDSubEdit to position the subtitles a bit higher. -
so i put the dvd through DVDSubEdit after i have made the dvd from dvdlab?.
Yes.
In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move. -
SVCDs usually have the subs burned in. Sounds like an overscan issue to me.
nirbhayn, do you even know whether or not your subs are selectable? If they're not, all you can do is reencode, adding black around the outside so the subs become visible. -
i dont have subs on the original svcd but i tried putting svcd subs but i cant see them. which player to use
OK, my mistake then. You said also that they were half off the bottom, and now you can't see them at all?
If they're on the DVD but too low, then you take träskmannen's advice and use DVDSubEdit to raise them. Here's the guide:
https://www.videohelp.com/~DVDSubEdit/UserManual/helpfile.htm
Section 2.7 explains how to raise them and sec. 2.1 explains how to apply and save the changes for all subs.
Chinese & Serbo-Croatian subtitles corrupted in DVDLab Pro
By umforrest in forum Authoring (DVD)Replies: 3Last Post: 27th Aug 2011, 14:17 -
Problem with subtitles off by default in DVDlab-pro
By blajko in forum Authoring (DVD)Replies: 2Last Post: 6th Sep 2010, 20:21 -
Overlapping subtitles on DVDLab Pro
By ikarishinji41 in forum Authoring (DVD)Replies: 3Last Post: 18th Jun 2010, 04:06 -
Subtitles in DVDLab Pro 2
By lorix in forum Authoring (DVD)Replies: 13Last Post: 13th Nov 2008, 15:09 -
VCD to DVD with subtitles in DVDlab Pro - subs 'disappear'...
By nbarzgar in forum Authoring (DVD)Replies: 0Last Post: 11th Jun 2007, 11:16
