I simply want to create a SVCD image in VCDEasy using multiple mpegs. The problem is, when i put the disc in a standalone player, at the beginning of each file "Select" blinks on the screen for the first few seconds of playback. It does it with each file, eg - hit play, 1st file starts & select blinks, press "next" key, skips to second file, "select" flashes again onscreen for the first few moments of playback. It's like the player thinks each mpg sequence is a menu for the first few seconds. How do i get this to go away? It doesn't do it with nero burnt SVCDs, but i want to use vcdeasy for the ability to time search. tia ...
