I'm trying to backup this dvd thats gotten a bit scratched after a while and cleaning it doesn't seem to do the trick. I know theres methods with using wax or polishing it etc. But I was wondering, since I remember hearing about a program DVDXRescue that was supposed to recover damaged dvd files. Does it really work or is it kind of effective? Also if there another alternative program that works as good or better?
Thanks in advance![]()
ISOBuster is one alternative. Some swear by DVD Fab Decrypter as well for stubborn discs. Be aware though, if you hit a patch and elect to ignore read errors, you will be throwing away data. Throw away enough and you will start to see visible effects.
Read my blog here.
Ok, trying it out now. I was only unable to copy 2 one gig files using decrypter. Unfortunately, with dvdfab it wouldn't just copy the files i needed, it wanted to copy the whole disc again. So I removed the old folder. It's been running for a little bit and nearly finished but its taking a real long time. I noticed some of files seem a bit smaller like 100-200KB smaller than they should be. But seems like its getting the job done =) Thanks gunslinger
A program that does something similar to the Re-author function dvd shrink?
By Bruxo in forum DVD RippingReplies: 5Last Post: 5th Jun 2011, 05:57 -
Mac audio program similar to BeSweet?
By bgart13 in forum MacReplies: 2Last Post: 26th Jan 2011, 05:44 -
Newbie looking for a video editing program similar to Windows Movie Maker
By Anonymous74 in forum EditingReplies: 3Last Post: 18th Sep 2008, 01:48 -
How can I rescue video from a DVD?
By OM2 in forum Newbie / General discussionsReplies: 2Last Post: 26th Mar 2008, 13:46 -
Can someone recommend a freeware program similar to AOA dvd ripper?(youtube
By tecmobo34 in forum Newbie / General discussionsReplies: 2Last Post: 28th May 2007, 16:16
