I have a camera that records in mp4 and I am trying to convert the videos to dv avi or quicktime MOV so I can edit them in premiere but I'm having problems.
Quicktime Pro converts to MOV but doesn't play or encode the sound.
VirtualDub doesn''t have any support for MP4
Winavi converter can't read mp4.
Thanks for your help...
Multimedia Design student getting an AAS in Springfield, Oregon. I like Gymnastics and DVD authoring. I think the two go nicely together.
tried mp4cam2avi ? then you might be able to import directly in premiere or reconvert to dvavi with virtualdub.
Things still aren't working. I just found that the conversion that quicktime pro does of mp4 to mov does not open in premiere.
I tried MP4Cam2AVI_v2.27 and it makes a divx file which virtualdub can open but can't encode to dv with panasonic dv codec.
I tried opening the divx file MP4Cam2AVI_v2.27 in premiere in video for windows mode and it kind of opened it but there are only black frames. When I tried to export that to dv avi it made a file with nothing but black frames.
There must be a way to do this. I just want to edit the video from my Sony Cybershot. I need to convert from mp4 to dv avi or quicktime MOV.
Thanks for the help...Multimedia Design student getting an AAS in Springfield, Oregon. I like Gymnastics and DVD authoring. I think the two go nicely together. -
actually nevermind-i found a way to convert to dv/dvcpro under the export to avi setting in quicktime pro
MPEG StreamClip - H.264 MP4 w/AC3 audio loses audio
By the_wallcrawler in forum Video ConversionReplies: 5Last Post: 25th Jan 2014, 03:05 -
MP4 w/ AAC ---> MP4 w/Compatible Audio
By NotSoEasy in forum Newbie / General discussionsReplies: 3Last Post: 26th Aug 2011, 15:41 -
trouble with audio after appending a .jpg turned .mp4 to another .mp4
By canadianjameson in forum Newbie / General discussionsReplies: 7Last Post: 26th Jun 2011, 09:55 -
mp4 to mp4 and keep original audio
By jntaylor63 in forum Video ConversionReplies: 3Last Post: 24th Mar 2009, 13:16 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 04:12
