  1. I'm reasonably sure that this is the proper forum for this topic.
    Problem:
    - Rip DVD to hard drive successfully (no errors in DVD decrypter).
    - Open rip folder contents in DVD Shrink successfully.
    - Backup with intention to burn to blank DVD or ISO.
    - Backup encoding process stalls at 0%, crashing DVD Shrink.
    Error message: "programming error -exception occurred"
    Programs utilized:
    Ripit4me 1.4.7.0
    DVD Decrypter 3.5.4.0
    DVD Shrink 3.2
    PgcEdit 7.3
    PSL2 plugin ver 2.21 for PgcEdit (psl2_plugin.tcl, FixVTS.exe, crc32.exe)
    VobBlanker 2.1.1.0
    Since the initial failure:
    1. I have tried rebooting my machine several times - no change.
    2. Ran PgcEdit to see if there are other problems with files - none.
    3. Also ran the files through both FixVTS and Vobblanker just to see the results - no change.
    Any input you could provide would be greatly appreciated.
    Thank you,
    Bleach Clean
  2. run a reg clean and /or reinstall dvd shrink
    PAL/NTSC problem solver.
    USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS
  3. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    You could just try ripping again using the latest DVDFab Decryptor.
    Google is your Friend
