Hi.
I have a Encore DVD project (4.7 GB), where the complete footage is DVD compliant (GOPs < 15 frames, total bitrate < 9.8 Mbps, DD or PCM audio, ...). The footage comes from DVB-S (satellite), went trough Cuttermaran (for cutting and to make sure it is DVD compliant).
All assets in Encore are set to "Don't transcode".
Now ... when building the DVD, Encore 2.0 starts to transcode video, despite the fact all footage streams are set to "Don't transcode". If I let the DVD build, I get 7.73 GB in the VIDEO_TS folder. The total of the footage is only 4.22 GB.
I.e. for some reason, Encore transcodes video, which is DVD compliant.
I'm really stuck at this point!
Any ideas ... ?!?!
Also see:
http://www.geohei.lu/downloads/temp/adobe_encore_dvd_1.jpg
http://www.geohei.lu/downloads/temp/adobe_encore_dvd_2.jpg
http://www.adobeforums.com/cgi-bin/webx/.3bc1416c/12
Thanks,
It's apparently a problem with open GOPs.
Can someone confirm that:
1. Closed GOPs are DVD-compliancy requirement?
2. Encore requires GOPs to be closed?
Thanks.
Ripping Episodes without Encore Trying to Transcode - Anyone?
By jdmba in forum DVD RippingReplies: 1Last Post: 2nd Aug 2011, 13:48 -
Encore CS4 DVD Image Build is incredibly slow
By aple in forum Authoring (DVD)Replies: 1Last Post: 22nd Jul 2011, 11:42 -
Finished DVD in Premiere CS5 - transcode in Encore?
By Mylo in forum Authoring (DVD)Replies: 4Last Post: 23rd Feb 2011, 08:55 -
encode/transcode: Why use Encore rather than Premiere Pro?
By vid83 in forum Authoring (DVD)Replies: 2Last Post: 11th Jul 2008, 19:31 -
Encore CS3 - deletes part of video from timeline during build?!?
By sdsumike619 in forum Authoring (DVD)Replies: 0Last Post: 11th Nov 2007, 14:53
