Hi there.
I've had so much trouble with this damn TV Tuner ni the past years, but I finally got it to work.
However, I had unknowingly been recording the files in the resolution of 704x576, which isn't a big problem, but now that I changed my computer, and had to re-install LifeView, I can't record the files in 704x576.
Anybody know how to change that setting? I could use TMPGEncoder to change it afterwards, but that would take a very long time to do.
At 720x480, I'm going to record at that for now I suppose, then transform it to the other one.
Reinstall of this type of card .
Unistall all related software and then driver's to device .
Shutdown pc ... remove card .
Back in os ... reinstall software for device only
Shutdown pc ... reinstall card .
Back in os ... reinstall driver's for device
Reset in program option's choice of format ... nstc or pal
Had the 3000 series running at 720x576 a few year's back ...
Now 704x576 ... still think issue related to sp2 ...
Was working correctly before ...
Moved on to avertv usb2 .
LifeView Video III Cable, Looking for Pin Outs or Substitute.
By Computer Nerd Kev in forum Capturing and VCRReplies: 0Last Post: 27th Nov 2011, 05:44 -
A working XP SP3 driver for Flyvideo 98 - Please help
By danroberto in forum Capturing and VCRReplies: 5Last Post: 28th Aug 2010, 13:10 -
LifeView Ultra TV Walker External USB software crashes HELP!
By robtom1966 in forum ComputerReplies: 2Last Post: 8th Nov 2007, 21:14
