I'm trying to capture some commercials onto my DVD recorder. I'm looking for a rewritable DVD media, since commercials only last 30 seconds, and I could be using the rest of the disk for other things. (I'd be recording shows on the timer while I'm at work, which is why I wanted a rewritable media)
My question about DVD-RW is, is it true that they are only temporary? If I fill a DVD-RW up and finalize it, how long will it work before I need to get it backed up?
And what is that (V) they always have after "DVD-RW" that I had to format before I could use a DVD-RW?
Are DVD-RAM's popular with home PC DVD drives? Or would it only be viewable on my DVD Recorder? Will the future home DVD players play DVD-RAM?
A1) They last a few years
A2) Format as UDF, perhaps?
A3) No, not popular at all. DVD-RAM was first out the door, but suffers from very poor compatibility, due to its initial "cartridge" format. Only recent drives solved that problem. However, DVD-RAM is built for rewrite, with multi-layer each that can do thousands of rewrites compared to hundreds for regular RW media.
A4) Likely NOT, as home players are moving to blu-ray or HD, neither is compatible with DVD-RAM. -
I could be wrong but that (V) might mean that you are recording in DVD-Video file format as opposed to VR. VR poses compatibility problems. UDF refers to disc format, not file format i.e. Video's IFO/VOB as opposed to VR's IFO/VRO.
Player to play 2 separate videos side by side for 3D effect ?
By andy15star in forum Software PlayingReplies: 9Last Post: 21st Jan 2012, 13:52 -
How Create ACHD side by side compatible with Panasonic 3D Cam and HDTV?
By castana in forum Video ConversionReplies: 7Last Post: 25th Jul 2011, 16:47 -
[solved]3d side-by-side capture and conversion to anaglyph using VirtualDub
By jumpjack in forum Capturing and VCRReplies: 21Last Post: 13th Apr 2011, 20:23 -
Is the panasonic dmres46v a seudo svhs side-by-side player/recorder?
By yoda313 in forum RestorationReplies: 8Last Post: 17th May 2010, 09:09 -
Is it safe to sell our free cell-phones? Also, is it safe to BUY?
By siratfus in forum Off topicReplies: 3Last Post: 12th Dec 2009, 16:30
