Here's my dilema: We have one TV with a comcast cable box that gets oodles of channels but only basic cable is on the other TVs in the apartment. I have a cheapie capture card: a kworld model tv878SEC that allows a backup PC (no drivers available for my new Win XP64 PC) to double as a TV in the kitchen. What I'd really like to do is use the back up PC as another digital cable TV so I can watch my White Sox games etc. Is there software or maybe a better quality card on the market that can process a digital signal in the same way that my cable box does? I want the same digital cable in the kitchen that I already have in my living room without having to get another box. Thanks alot.
You will need another cable box from your cable company. Most tuner cards only receive the "free" (non scrambled / non digital) channels. I believe there are some newer ones that can receive digital channels, but you will need to contact you cable company to see if any of them are compatible with their system.
Google is your Friend
Will my store-bought DTA box do the same thing as a Comcast DTA box?
By locust78 in forum DVB / IPTVReplies: 7Last Post: 25th Feb 2013, 19:26 -
How to capture cable box output to PC
By mickelsen in forum Capturing and VCRReplies: 7Last Post: 1st Jan 2012, 19:13 -
Look what I found-a Motorola DCH3200 set-top box for use with Comcast cable
By zoobie in forum DVB / IPTVReplies: 7Last Post: 15th Dec 2010, 21:27 -
Unable to use HDMI cable with Scientific ATlanta 8300 DVR cable box
By aimee43 in forum DVB / IPTVReplies: 11Last Post: 28th May 2009, 13:21 -
Connecting an lcd to a comcast tv box?
By Gplracer in forum DVB / IPTVReplies: 0Last Post: 10th Aug 2008, 21:58
