  1. Is there a Reverse Bit-Rate Calculator?
    I know there is already a bit-rate calc here: https://www.videohelp.com/calc.htm
    But is there a way to calculate how big of a file size is if you set the bit-rate?
    For example:
    Lets say I have a video (VHS) that is 1hr:30min long, and I want to capture:
    VIDEO: at 352x480 and 15,000kbps CBR
    AUDIO: 384kbps MP2 audio
    ... what will the file size be?
  2. Multiply the bitrate by the running time in seconds, then divide by eight. That will give you bytes. Assuming 15,000 kbps is 15,000,000 bps, 90 minutes = 5400 seconds
    15,000,000 bps * 5400 seconds / 8 = 10,125,000,000 bytes
  3. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    If I didn't make a mistake, I think this is it.
    5400 seconds * 15,000 Kb/s = 81,000 Mb = 10.125 GB
    352x480 and 720x480 would be the same file size.
    http://www.kiva.org/about
  4. Member edDV's Avatar
    Mar 2004
    Plus 259 MB audio
  5. Member GeorgeW's Avatar
    Feb 2005
    In the bitrate calculator link you provided, hit the Advanced Mode button top right corner, enter the audio bitrate and duration, and then input your video bitrate in the Calculated Bitrate field -- your resulting size will be in the Custom Size field
    Regards,
    George
  6. Originally Posted by GeorgeW
    Regards,
    George
    I didn't relize you could adjust the "Calculated Bit-Rate" and "Max Bit-Rate" fields... must have not hit the advance button.
    Thanks Everyone, sorry.
