I have a question. I have vob files, with a low quality sound(it's too quiet), but good quality video. I know that I can make the sound much better using GoldWave and than save it as WAV or MP3, but my question is; is there any kinda simple tool, that would let me, connect the new better quality audio file with the video, kinda like the way Virtual dub does, but I don't want to loose any quality, and the most important too, I want the files to stay in VOB format, so I could later make a DVD of them.
Results 1 to 13 of 13
Demux the video (m2v) and audio (mp2?) from the VOB with ReJig.
Treat your audio the best you can - save as wav and/or convert to AC3 or MP2. Author as DVD with any authoring ap that handles elementary streams. (TDA, DVD-Lab & c) The video will be untouched, with your new & improved audio. VOB is not what you feed into an authoring app - it's part of the output from creating a DVD.
m2v + DVD compatible audio (WAV, AC3, MP2) is the best you can have as source material for creating a DVD.
/Mats -
You will also have to pay attention to the bitrates used. You can't re-encode your audio with too high a bitrate if video is taking up more than its fair share. To play it safe, re-encode audio using the exact same bitrate the old audio was encoded at.
Darryl -
yes, ok, but can anyone tell me, how do i do all of this exactley? because i don't have a clue, how to extract, the audio in to ac3 using rejig, and how exactley do i pu it together with audio in dvd lab pro
i tryed to do this with rejig, and i succeded to make the m2v video and ac3 audio, but i see that the video became worse after that... why do you tell me, it will not be ruined, i see it is... besides Gold wave stopped axepting vob files after i istalled rejig and dvd lab.. now it doesnt open it anymore, i see it doesn't work.
No it didn't. If all you did was to demux, the video is exactly the same.
It's probably just your filter. Install the AC3Filter and jack up the volume. One way is to use the "Loud" preset. There's probably nothing at all wrong with the audio if it's from a commercial DVD. Once you back it up to another DVD and play it in your player, it'll sound just fine. -
Unless you also shrunk (transcoded) the video with rejig, the video is untouched, and no quality is lost. It will be exactly what it was in the VOB, just taken out of its "envelope".
Plenty of help with DVD-Lab at the developers site http://www.mediachance.com/
Why Goldwave wouldn't open VOB files after installing Rejig and DVD-Lab, I've got no idea. Didn't even know it did at all (but then, GW seems to open anything with some kind of audio so I shouldn't be surprised). What error message do you get when you try?
/Mats -
Originally Posted by manono
Originally Posted by mats.hogberg
ok, thanks for everyones help on that subject, i just changed the audio settings.
Originally Posted by Remyisme
/Mats
How to add selectable audio to a video without quality loss
By m.eshi in forum EditingReplies: 2Last Post: 27th Aug 2011, 09:09 -
Splitting VOB files with audio delay/quality loss?
By S0VIET in forum Authoring (DVD)Replies: 8Last Post: 30th Oct 2010, 21:48 -
Convert .vob to another format with max quality
By alexv305 in forum DVD RippingReplies: 7Last Post: 19th Jun 2010, 22:36 -
VOB & MPEG4 HD to Windows Media Compatable Format (DVD Quality?)
By RobsterNo1 in forum Video ConversionReplies: 2Last Post: 28th Oct 2008, 06:49 -
Cutting .vob file in .vob format only
By rahul.never2far in forum EditingReplies: 11Last Post: 1st Oct 2007, 08:52
