Hello!! How are you?
I have a 640x272 video that I converted it with Winavi video converter to MPEG 2 with the same size.
When I go into the asset part in DVd lab pro to import the movie a get this error
The original Avi was of 700 mb.
Winavi reduce it to 658.
I first tried with Total video converter and the new MPEG2 was o more than 1 Gb.
MPEG2 properties of Total video converter:
Same size and audio. I tried both aspect ratio and I got a full screen on TV. 6 hours and one DVD lost.
MPEG2 properties of WinAvi
size 720x 304. I put 4:3 as aspect ratio. But seeing it with Crystal video player I can change it. Yo see the size I put, I have to choose 45:19 aspect ratio
This is the error DVD lab pro pops up
What can I do?
Thank you very much!![/img]
This is more a conversion issue. Moving you.
You must convert to a dvd compliant mpeg2 file, www.videohelp.com/dvd#tech
And use a good encoder like tmpgenc xpress and select dvd and it will be dvd compliant.
Or use divxtodvd (very good support for downloaded video), it outputs a complete dvd directly... if you want to make menus with dvd-lab pro can you import the vobs created by divxtodvd. -
Thank you, Baldrick
I have read the link you gave me and find out that maybe the problem is the size 640x272.
I'll try change it to 720x576 and aspect ratio 16:9.
I'm download the program. the problem is that my borther forgot his passworf of the Administrator account :P.
See you around -
Hi again!!
Well,. with Total video converter, i chose 720x576 and aspect ratio 16:9 and got very good results!
Thank you so much for the help!
How to change menu aspect ratio in DVD-Lab Pro ?
By V879 in forum Authoring (DVD)Replies: 2Last Post: 1st May 2011, 16:11 -
DVD Lab Pro Audio Problems
By Outcast212 in forum Newbie / General discussionsReplies: 6Last Post: 21st Feb 2009, 02:11 -
Having problems understaing aspect ratios
By PlayWithFire in forum Newbie / General discussionsReplies: 2Last Post: 16th Nov 2007, 09:40 -
Vob File has a aspect ratio of 704X480 in Dvd Lab Pro.
By mlong30 in forum Authoring (DVD)Replies: 4Last Post: 16th Jul 2007, 23:24 -
Aspect Ratios / Dimentions / HD Problems
By Aviewanew in forum EditingReplies: 8Last Post: 21st May 2007, 22:23
