using 8000cbr & slow & extreme ac3 384 2 pass. captured as 720 x 480 uncompressed avi from sony vcr. at times it all looks good and then blocks will appear & then dissappear
We need more information.
Since VCR is an analog device, what method did you use to create the uncompressed avi? Is it really uncompressed or is it DV-AVI (Type 1 or Type 2)? Did you drop any frames in the process? Did you review the avi before attempting the encode? What are you encoding to? What are you playing the encoded video in when you see the blocks? Can you locate the "blocky" frame(s) when stepping frame by frame? Why 2 pass for 8000cbr? What slow and extreme settings have you set?"Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
since i posted this i tried all the que enc settings the same but checked use vbr. the blocks seem to not be there now when encoding the same segment .
settings i used for que enc:
8000 cbr-high quality-2 pass-mpeg2- (under advanced options)- extreme & slow settings-interlaced incoding-top field first-9800 max bitrate-ac3 384 audio
as i say i checked the use vbr box & reencoded with better results. when i check each file with media info it says the first(blocky) has bit rate 8000 cbr & the second with vbr has 9800 bit rate cbr. why would it say the vbr file has cbr of 9800? is that 9800 total including audio? i seem to recall that 9800 total is high mark for dvd campatabilty right? would a 1 pass be just as good with a high bitrate? how much do you think i'm gaining with slow & extreme settings? it does take forever. 15 minutes takes about 2 hours or so on 3 ghtz conputer. i captured from composite to 7800gt nivedia card. used virtual vcr. media info says the avi is uncompressed yuv 16bpp. i don't think i've been dropping that many frames. used power dvd 5 to view. what does it mean when the que enc encoder says there are x amount of possible overflows after encoding? -
I don't know unless it's reporting the max bitrate.Originally Posted by resohed
Yes the combined audio and video max for DVD is 9800. QuEnc will allow for higher values than this if your video is not destined for DVD so you should use a bitrate calculator to determine the correct bitrate.Originally Posted by resohed
yesOriginally Posted by resohed
it depends on the source, but if you are very close to the max then nothing can be gained by using vbr and 2-pass.Originally Posted by resohed
Probably very little. In the readme notes the author advises against using this setting as experimental.Originally Posted by resohed
I've never received that message but I would assume that it's pointing out that at some points in the encoded video the combined audio and video bitrate exceeds the DVD specs. It's just warning you in case your destination is DVD.Originally Posted by resohed"Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books
HC enc: Your settings ?
By themaster1 in forum RestorationReplies: 6Last Post: 21st Oct 2011, 20:55 -
ENC encoding versus no ENC encoding
By RL in forum ffmpegX general discussionReplies: 3Last Post: 4th Feb 2011, 18:44 -
how do I convert a video that shows square pixels to no pixels?
By sxpredman in forum Newbie / General discussionsReplies: 4Last Post: 10th Jan 2010, 03:56 -
Another question: Converting square pixels into round pixels.
By Earthling2000 in forum Newbie / General discussionsReplies: 13Last Post: 23rd Nov 2009, 11:20 -
Something better Tmpeg Enc
By 02fx4dude in forum Video ConversionReplies: 4Last Post: 15th Aug 2007, 07:23
