Hi,
I want to split in Adobe Premiere the captured DV (type 2, PAL) file into smaller files with the same DV format.
After capturing (in DV format), I can read the timecode of captured files with e.g. https://www.videohelp.com/tools?tool=DVdate
After importing the file into Adobe Premiere, cutting out some parts of video, splitting it, and finally exporting it in the same DV format, there is no more timecode in the exported file. The https://www.videohelp.com/tools?tool=DVdate shows no values.
I would like the Adobe Premiere to preserve the timecode when exporting from DV to DV.
Does anybody know how to do it?
Thanks[/url]
Hi,
Welcome to the forums.
It'll mean that you'll have to recapture again, but WinDV is an excellent tool for this. Read here first:Originally Posted by indian-gumkac
https://forum.videohelp.com/viewtopic.php?p=1387878#1387878There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Well,
I recaptured it again with WinDV and it's much more better than Adobe Premiere as far as capturing is concerned.
Thanks -
Carpe diem.
MKV & Adobe premiere: Best method to import without quality loss
By libjoe67 in forum EditingReplies: 34Last Post: 19th May 2012, 16:34 -
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 22:43 -
Loss of audio in Premiere Pro
By Martha in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 22nd Feb 2011, 04:45 -
Adobe Premiere 1.5: Adobe Media Encoder: Frame size and scaling?
By vid83 in forum EditingReplies: 2Last Post: 30th Nov 2008, 04:17 -
Adobe Premiere Capabilities
By jwfc in forum Newbie / General discussionsReplies: 2Last Post: 22nd Oct 2007, 17:18
