I recently reinstalled SVCD2DVD on a revuilt computer. FOr some reason, when SVCD2DVD calls NEROBurner to burn a DVD, the burn stops after about 30sec.
Burning DVD folder
03:13:14: Starting NeroBurner...
03:13:40: NeroBurner...Done
03:13:40: Done: Burning DVD folder
I can burn the same DVD folder successfullly using NeroBurner directly.
Any idea what the problem might be?
Does it spawn the NeroBurner applet?
Can you attach your neroburner log for the failed run? (It should be in the logs folder under SVCD2DVD exe)
Here is what the log looks like when SVCD2DVD trys to call NeroBurner
********************** NEROBURNER *******************
03:13:26 DVD-Video files reallocation started
03:13:26 DVD-Video files reallocation completed (no file modified)
03:13:26 DVD-Video files sorted
03:13:27 Caching of files started
03:13:27 Caching of files completed
03:13:27 Burn process started at 8x (11,080 KB/s)
03:13:39 Unspecified Recorder Error
F: _NEC DVD_RW ND-3550A
03:13:39 Could not perform end of Disc-at-once
03:13:39 Burn process failed at 8x (11,080 KB/s)
03:13:40 DVD NOT burned sucessfully
If I run it ouside of SVCD2DVD it looks like
05:05:56 DVD-Video files reallocation started
05:05:56 DVD-Video files reallocation completed (no file modified)
05:05:56 DVD-Video files sorted
05:05:56 Caching of files started
05:05:57 Caching of files completed
05:05:57 Burn process started at 8x (11,080 KB/s)
05:15:20 Writing short lead-out
05:16:00 Burn process completed successfully at 8x (11,080 KB/s)
05:16:02 DVD burned sucessfully -
Is _NEC DVD_RW ND-3550A the correct DVD recorder? Is it this one you use with NB standalone?
is an error which I get intermittantly from Nero and have associated with bad media. Usually the next disk burns just fine.
Get about two per 50 pack from CMC media.
SVCD2DVD and then burning with imgburn fails
By baby2003 in forum Authoring (DVD)Replies: 5Last Post: 7th Sep 2010, 14:57 -
Autocrop fails
By w4tt4n4b3 in forum EditingReplies: 0Last Post: 11th Oct 2009, 15:31 -
mencoder fails
By scruss1 in forum Video ConversionReplies: 1Last Post: 11th Jan 2009, 23:48 -
burns fails. help
By dymx in forum Newbie / General discussionsReplies: 8Last Post: 18th Jun 2008, 14:54 -
Burning always fails at 98%...
By Variable in forum DVD & Blu-ray WritersReplies: 14Last Post: 29th Feb 2008, 16:45
