hello there... i'm newbie here... just wondering what is this file all about... is it new version of RM file?? try to play it with Real Player or Real Media but it's not working... what player are suitable for this file?? and any converter to convert it (RMVB file) into AVI or MPEG??? thank you for the thought...
Not a new version it is a rm file. They just renamed the extension to distingish newer variable bitrate files from old CBR files. The actual container is still the same.
Real Player should play it just fine. Fact is that any other player or converter is just using the same real video decoder since the only on in existance is from real. -
rmvb means either Real Video 9 or Real Video 9 EHQ (aka Real Video 10) which libavcodec can't handle and unless things have changed VLC can't load real dll's for decoding, so it can't handle the video streams of rmvb files.
If you want a player that really can handle almost everything, I would suggest mplayer. As per my above point though, it requires a decoder from real. Basically just copy the dll to your codec dir and you are done though. Also there are packages with GUI, real decoders, etc. -
-edit-
mentioned warez
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator offline -
I only know that RMVB=Real Media Variable Bit rate and would like to learn more about it.
Sam Ontario -
Real Alt is just that rubbish from real repackaged illegally without the player. As I said, there is no alternative. The only decoder for RV30/RV40 is from real.
Anyway, I just tried VLC (0.8.6svn build) and it wouldn't load the video. As far as I know the devs made a decission to not load external codecs for propriatry formats. -
And without the spyware too. And, yes, even the newer versions are spyware-ish. There's an advantage to not including the player.Real Alt is just that rubbish from real repackaged illegally without the player. As I said, there is no alternative.
rmvb help
By aimbdd in forum ffmpegX general discussionReplies: 4Last Post: 7th Aug 2008, 20:22 -
Help on RMVB
By JohnConstantine in forum Newbie / General discussionsReplies: 1Last Post: 20th Jan 2008, 09:30 -
RMVB
By magius in forum AudioReplies: 4Last Post: 7th Jan 2008, 10:26 -
rmvb to dvd?
By asdfprou in forum Newbie / General discussionsReplies: 8Last Post: 29th Nov 2007, 02:20 -
RMVB file???
By BigCol in forum Authoring (DVD)Replies: 1Last Post: 13th Jul 2007, 18:23
