Hi,
Since i replaced my Samsung 172x LCD (17") with a 20" Acer Widescreen LCD i began to see some thing on the screen that i hadn't noticed before, here's an example from the Samsung HD Demo....
http://img83.imageshack.us/img83/8097/pdvd031iz0.jpg
It's seems to occur only when there's rapid movement or quick panning by the camera
This also can be seen when watching DVB in either SD or HD, here's a screen cap...
http://img97.imageshack.us/img97/9332/bi0814215121my5.jpg
So the big question is...is there something wrong with my setup or is it something to do with the videos/DTB and i just have to live with it ?
Thanks for any input![]()
It's normal for rapid movements and water especially. The blockiness has nothing to do with the monitor...you may just notice it better with a bigger monitor.
Are you using same player, graphic card as before? -
Yep, all the same hardware as before. My first thought was the monitor but i hooked my 17" LCD again and the pixelation was there, just harder to see. I also tried 17" CRT that i have and it was visable with that as well if i looked close enough. Like you say with the bigger screen these thing are just more noticable. Why would the pixelation occur with some videos and not others?. I tried a couple of Quicktime HD Trailers like Spiderman 3 HD, Madagascar HD , Elephant's Dream HD (DivX) and they all played fine, especially the Quicktime ones although there was no water scenes in any of these vids but plenty of rapid movement/action, also DVD's seem to play fine as well. One more thing, would this be less noticable on a LCD TV ? not that i'm thinking of changing, just curious.Originally Posted by Baldrick
cheers
change aspect ratio & convert m2ts files & brighten videos
By rockerman in forum Newbie / General discussionsReplies: 3Last Post: 21st Jul 2011, 08:34 -
DVB-S/DVB-S2 Satellite Receiver with direct HD,SD/SDI output not HDMI
By rahemeen in forum DVB / IPTVReplies: 1Last Post: 19th May 2011, 06:38 -
Help with DVB-S2 videos.
By Toto87 in forum Newbie / General discussionsReplies: 3Last Post: 8th Aug 2008, 16:02 -
Non-compliant resolutions (DVB & SATV)
By DRP in forum Video ConversionReplies: 12Last Post: 1st Oct 2007, 15:48 -
Watching videos on my computer results in weird pixelation and blurring
By dan1230 in forum Newbie / General discussionsReplies: 9Last Post: 4th May 2007, 12:46
