While trying tocpy a DVD (recorded on a DVDRW) to a blank DVD directly, I get an error.
I even tried creating an image of the source DVD using Nero and then tried to burn it to the blank DVD (again using NVE). I am getting the following error. Woudl really appreciate if someone could help me out.
Code:Sir G Sir Org. Windows XP 5.1 IA32 WinAspi: - ahead WinASPI: File 'D:\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 11/2/2004 12:54:32 PM NT-SPTI used Nero Version: 7.0.8.2 Internal Version: 7, 0, 8, 2 (Nero Express) Recorder: <SONY DVD RW DW-Q120A> Version: PYS2 - HA 1 TA 1 - 7.0.8.2 Adapter driver: <USB 1.0> HA 1 Drive buffer : 2048kB Bus Type : set to ATAPI (3) -> ATAPI, detected: ? CD-ROM: <HL-DT-ST RW/DVD GCC-4522B>Version: 1.03 - HA 1 TA 0 - 7.0.8.2 Adapter driver: <IDE> HA 1 === Scsi-Device-Map === DiskPeripheral : SAMSUNG SP4002H atapi Port 0 ID 0 DMA: On CdRomPeripheral : HL-DT-ST RW/DVD GCC-4522B atapi Port 1 ID 1 DMA: On === CDRom-Device-Map === HL-DT-ST RW/DVD GCC-4522B E: CDRom0 SONY DVD RW DW-Q120A F: CDRom1 ======================= AutoRun : 1 Excluded drive IDs: WriteBufferSize: 73400320 (0) Byte BUFE : 0 Physical memory : 503MB (515568kB) Free physical memory: 161MB (165320kB) Memory in use : 67 % Uncached PFiles: 0x0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 15.8.2006 DVD-Copy on the fly 1:21:08 PM #1 Text 0 File SCSIPassThrough.cpp, Line 39 SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME 1:21:08 PM #2 Text 0 File SCSIPassThrough.cpp, Line 84 SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME 1:21:08 PM #3 Text 0 File ThreadedTransfer.cpp, Line 531 ReadBuffer-Pipe got 71680KB of Memory 1:21:08 PM #4 Text 0 File Reader.cpp, Line 124 Reader running 1:21:08 PM #5 Text 0 File Writer.cpp, Line 113 Writer F: SONY DVD RW DW-Q120A running 1:21:08 PM #6 Text 0 File DVDCopy.cpp, Line 292 DVD Track-Information from source disc: Media Type: DVD-RW S01 T01 Con 0x14 Start 0 Len 1282320 (gap 0) Blank 0 Res 0 Dmg 0 Open Trk 0 Mode TRM_DATA_MODE1 (0) 1:21:08 PM #7 Text 0 File DVDCopy.cpp, Line 405 Max -1 tracks of 1 allowed to copy 1: 0 - 1282320 = 1282320, TRM_DATA_MODE1, block size 2048, read opt 0 (no read options) 1:21:08 PM #8 Text 0 File Burncd.cpp, Line 3353 Turn on Disc-At-Once, using DVD media 1:21:09 PM #9 Text 0 File DlgWaitCD.cpp, Line 289 Last possible write address on media: 2295103 (510:01.28, 4482MB) Last address to be written: 1282319 (284:57.44, 2504MB) 1:21:09 PM #10 Text 0 File DlgWaitCD.cpp, Line 301 Write in overburning mode: NO (enabled: CD) 1:21:09 PM #11 Text 0 File DlgWaitCD.cpp, Line 2715 Recorder: SONY DVD RW DW-Q120A, Media type: DVD+R Disc Manufacturer ID: SONY, Media Type ID: D21, Product revision number: 0 Disc Application Code: 0, Extended Information Indicators: 7 1:21:09 PM #12 Text 0 File DlgWaitCD.cpp, Line 473 >>> Protocol of DlgWaitCD activities: <<< ========================================= 1:21:09 PM #13 Text 0 File ThreadedTransferInterface.cpp, Line 847 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 (1 - Data (mode 1)) 2 indices, index0 (150) not provided original disc pos #0 + 1282320 (1282320) = #1282320/284:57.45 not relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1282320 blocks [F: SONY DVD RW DW-Q120A] -------------------------------------------------------------- 1:21:09 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 1059 Prepare recorder [F: SONY DVD RW DW-Q120A] for write in CUE-sheet-DAO DAO infos: ========== MCN: "" TOCType: 0x40; Session Closed, disc fixated Tracks 1 to 1: 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 2626191360, ISRC "" DAO layout: =========== __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________ 0 | lead-in | 0 | 0x41 | 0x00 0 | 1 | 0 | 0x41 | 0x00 0 | 1 | 1 | 0x41 | 0x00 1282320 | lead-out | 1 | 0x41 | 0x00 1:21:09 PM #15 Text 0 File SCSIPassThrough.cpp, Line 39 SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME 1:21:09 PM #16 Text 0 File SCSIPassThrough.cpp, Line 84 SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME 1:21:09 PM #17 Phase 36 File dlgbrnst.cpp, Line 1730 Burn process started at 6x (8,310 KB/s) 1:21:09 PM #18 Text 0 File ThreadedTransferInterface.cpp, Line 2707 Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0 1:21:09 PM #19 Text 0 File Cdrdrv.cpp, Line 8661 ---- DVD Structure: Physical Format Information (00h) ---- Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050 Book Type: DVD+R (10), Part Version: 1.0x (1) Disc Size: 120 mm, Maximum Rate: <not specified> (F h) Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable Linear Density: 0,267 um/bit, Track Density: 0,74 um/track Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW) End Physical Sector Number of Data Area: 26053F h End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB) Data in Burst Cutting Area (BCA) does not exist Disc Application Code: 0 / 0 h Extended Information indicators: 7 h Disc Manufacturer ID: SONY.... Media type ID: D21 Product revision number: 0 Number of Physical format information bytes in use in ADIP up to byte 63: 56 Media Specific [16..63]: 00 00 07 53 4F 4E 59 00 - 00 00 00 44 32 31 00 38 ...SONY....D21.8 23 54 37 14 00 28 6E 00 - 80 69 17 19 0C 0C 0A 0B #T7..(n..i...... 01 19 1B 0B 0B 0E 0F 01 - 00 00 00 00 00 00 00 00 ................ 1:21:09 PM #20 Text 0 File DVDR.cpp, Line 6222 Drive: SONY DVD RW DW-Q120A Book Type request [LO], rev 3: DVD-ROM Changing the Book Type was finished successfully, return code 0 1:21:09 PM #21 CDR -1207 File DVDR.cpp, Line 5649 Book Type automatically set to: DVD-ROM 1:21:10 PM #22 Text 0 File DVDPlusRW.cpp, Line 666 Start write address at LBA 0 DVD high compatibility mode: Yes 1:24:18 PM #23 SPTI -600 File SCSIPassThrough.cpp, Line 290 F: CdRom1: SCSIStatus(x00) WinError(121) NeroError(-600) Sense Key: 0x00 (KEY_NO_SENSE) Sense Code: 0x00 Sense Qual: 0x00 CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00 Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00 Buffer x09500000: Len x10000 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1:24:18 PM #24 CDR -600 File Writer.cpp, Line 302 Device not available F: SONY DVD RW DW-Q120A 1:24:18 PM #25 Text 0 File ThreadedTransfer.cpp, Line 228 all writers idle, stopping conversion 1:24:18 PM #26 Text 0 File ThreadedTransfer.cpp, Line 222 conversion idle, stopping reader 1:24:23 PM #27 SPTI -600 File SCSIPassThrough.cpp, Line 290 F: CdRom1: SCSIStatus(x00) WinError(55) NeroError(-600) Sense Key: 0x00 (KEY_NO_SENSE) Sense Code: 0x00 Sense Qual: 0x00 CDB Data: 0x35 02 00 00 00 00 00 00 00 00 00 00 Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00 1:24:23 PM #28 SPTI -600 File SCSIPassThrough.cpp, Line 290 F: CdRom1: SCSIStatus(x00) WinError(55) NeroError(-600) Sense Key: 0x00 (KEY_NO_SENSE) Sense Code: 0x00 Sense Qual: 0x00 CDB Data: 0x5B 01 05 00 00 00 00 00 00 00 00 00 Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00 1:24:23 PM #29 Phase 127 File dlgbrnst.cpp, Line 1730 Generating DVD high compatibility borders 1:24:23 PM #30 SPTI -600 File SCSIPassThrough.cpp, Line 290 F: CdRom1: SCSIStatus(x00) WinError(55) NeroError(-600) Sense Key: 0x00 (KEY_NO_SENSE) Sense Code: 0x00 Sense Qual: 0x00 CDB Data: 0xAD 00 00 00 00 00 00 00 08 04 00 00 Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00 Buffer x0344d200: Len x804 1:24:23 PM #31 CDR -600 File WriterStatus.cpp, Line 167 Device not available F: SONY DVD RW DW-Q120A 1:24:23 PM #32 TRANSFER -24 File WriterStatus.cpp, Line 167 Could not perform end of Disc-at-once 1:24:23 PM #33 SPTI -600 File SCSIPassThrough.cpp, Line 290 F: CdRom1: SCSIStatus(x00) WinError(55) NeroError(-600) Sense Key: 0x00 (KEY_NO_SENSE) Sense Code: 0x00 Sense Qual: 0x00 CDB Data: 0x5A 00 05 00 00 00 00 00 48 00 Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00 Buffer x03421800: Len x48 1:24:24 PM #34 SPTI -600 File SCSIPassThrough.cpp, Line 290 F: CdRom1: SCSIStatus(x00) WinError(55) NeroError(-600) Sense Key: 0x00 (KEY_NO_SENSE) Sense Code: 0x00 Sense Qual: 0x00 CDB Data: 0x5A 00 05 00 00 00 00 00 48 00 Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00 Buffer x03421800: Len x48 1:24:24 PM #35 CDR -600 File WriterStatus.cpp, Line 172 Device not available F: SONY DVD RW DW-Q120A 1:24:24 PM #36 TRANSFER -39 File WriterStatus.cpp, Line 172 Could not perform EndSession 1:24:25 PM #37 Phase 38 File dlgbrnst.cpp, Line 1730 Burn process failed at 6x (8,310 KB/s) 1:24:25 PM #38 SPTI -600 File SCSIPassThrough.cpp, Line 290 F: CdRom1: SCSIStatus(x00) WinError(55) NeroError(-600) Sense Key: 0x00 (KEY_NO_SENSE) Sense Code: 0x00 Sense Qual: 0x00 CDB Data: 0x1E 00 00 00 00 00 00 00 00 00 00 00 Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00 Existing drivers: File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 5/20/2006 2:46:24 AM File 'Drivers\PXHELP20.SYS': Ver=2.03.28a, size=20640 bytes, created 10/27/2005 1:42:48 AM (Prassi/Veritas driver for win 2K) Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
I would try something else like DVD Decrypter, select ISO->Read to copy and ISO->Write to burn.
copy avi file from scratched dvdr
By octeuron in forum Newbie / General discussionsReplies: 7Last Post: 10th Mar 2010, 01:14 -
copy from DVDR to HDD
By sideskroll in forum DVD RippingReplies: 4Last Post: 15th Nov 2008, 15:15 -
What device will enable recording of TV to DVDR and DVD or VHS to DVDR?
By enricomad in forum DVD RippingReplies: 1Last Post: 26th Jun 2008, 17:46 -
Can I copy protect my DVDR's
By 557953 in forum DVD RippingReplies: 5Last Post: 15th Jun 2008, 17:41 -
can't copy home made dvdr
By pressthe6 in forum Authoring (DVD)Replies: 20Last Post: 29th Nov 2007, 10:35
