Results 1 to 11 of 11
  1. Member Beautiful Alone's Avatar
    Jul 2002
    are there any programs that allows your to set a password on the disc, so it can be only access by entering the password on the disc inorder to view it's content?
    Apr 2004
    Miskatonic U
    Practically - no. There are methods to add things like combination locks on screen - DVD Lab Pro can do this - however they are useless in any real sense. Play the files back on a computer and you avoid the lock.
    If you don't need the disc to be playable in a settop player you could always rar the files up with a password. Rar encryption is impervious to pretty much everything except brute force attack, so choose a good, long password and things will be safe.
    But anything you can put on a DVD front end will only slow down your grandma, but not stop a 10 year old boy.
    Read my blog here.
  3. Member Beautiful Alone's Avatar
    Jul 2002
    are you sure that nothing can lock up my dvd-r discs? ah! .rar files with password, i've never thought of that, good thinking, but dont you think it's alittle inconvenience everytime i wanted to open my files, there always a need to upzip it first?
    you ever heard of this program?
    http://img206.imageshack.us/my.php?image=secuviewermk5.png
    its called secu-viewer
    Apr 2004
    Miskatonic U
    There are dozens of encryption programs and access control programs that might help, however they have the inconvenience of locking you into using only one PC to access the content. At least with rar files the discs are portable. Regardless, anything that encrypyts or alters the files will render them non longer DVDs, and unplayable in any DVD player. They are only useful for data discs, and all solutions will impose some access inconvenience.
    Read my blog here.
  5. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Don't you think it's a little inconvenient every time you want to open your files, there's always a need to enter a password ?
    It may pay to read this:
    https://forum.videohelp.com/viewtopic.php?t=223640
    If in doubt, Google it.
  6. Member Beautiful Alone's Avatar
    Jul 2002
    all i want is a programs that locks my data's, no others.
    Nov 2002
    So encrypt only the data. What's the problem?
  8. Member Beautiful Alone's Avatar
    Jul 2002
    I dont know what program to use.
    Nov 2002
    So use... Winrar or Winzip
  10. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Haven't used it but give this a try: http://www.pgp.com/downloads/desktoptrial.php
    It's trialware but the major features such as single file encryption remain after it runs out. That product will make it inaccessible to anyone without the key. Once encrypted without the key even brute force would take what amounts to a infinite amount of time...
    Feb 2004
    Australia
    I always used camouflage ... http://camouflage.unfiction.com/
    Dont use text file's , as they can still see what has been wrapped using any half decent hex tool .
    User need's this tool , and the password to extract the file hidden within ...
    Read the instruction's ... it's simple , and free ...
    Winzip is crap ... ever checked running task's after using it several time's ...
    If you used it 9 time's , then closed it ... it's still running 9 time's in background task area ...
    Use zipgenious ... can unpack many format's , even extract file's from iso's ... and has password encrytion included ...
    Also scan your registry ... every archive you open with winzip add's a new line to the registry ... adding more rubbish where it shouldn't be ...
    Use regscanner from http://www.nirsoft.net ... it's fast at finding crap ... just type winzip , and let it rip .
