Sometimes when I capture certain video trhough canopus 110 into premiere...the video turns out "wavy" like theres something wrong with the balance...this is what i mean
Is there any way to diffuse this because it does show up on an NTSC monitor..though not quite as severe on a computer but still very noticeable...thanks
Results 1 to 10 of 10
That looks like a prime canidate for a TBC, regardless it has to be fixed before it get to the Canopus.
https://forum.videohelp.com/viewtopic.php?p=1115672 -
This type of error is precisely why I own a Panasonic ES10 DVD recorder, and use it for pass-through (just pass-through, not recording, Panasonic recording quality sucks). The JVC D-VHS machines (not S-VHS) can also fix this.
Standalone TBCs, and line TBCs found in most TBC'd VCRs, will likely NOT be able to fix this.Want my help? Ask here! (not via PM!)
Well as I said its a source issue...I viewed the source VHS and i do see those "waves" there too...so is JVC D-VHS or Panasonic ES10 my options? To be honest I dont want to get a DVD recorder just for pass through..and a TBC isnt viable for me right now budget wise
Is this recording a copy of a copy? If so, then significant improvement may not be possible.
Life is better when you focus on the signals instead of the noise. -
I'm only seeing a broken link for your Picture, however, as LS says, the ES-10 is great for fixing flagging, and it's about $180 at Costco. My TBC Full Frame cost me $300, so the Pany is a good deal all around.
"*sigh* Warned you, we tried. Listen, you did not. Now SCREWED, we all will be!" ~Yoda -
Could be RF interference, too. Check your cables & connections, and make sure you don't have some bad RF emitter nearby.
Scott -
I doubt it's RF interference.
I doubt it too, but it's certainly something to check for (sorry about the wires, Lordsmurf).
Scott -
Before going all out, have you just tried a different VCR (with errors like that I assume it is a VHS source)?
It won't completely fix the problem, but eh it is analog, strange things can help, and it might help "enough". And borrowing a VCR is free (if your time is free of course)
Would there ever be a reason to capture "upconverted" video?
By yoda313 in forum Capturing and VCRReplies: 11Last Post: 20th Mar 2010, 21:26 -
another "which to buy" video capture equipment
By CNT in forum Newbie / General discussionsReplies: 1Last Post: 18th Feb 2010, 14:10 -
How to Capture Video of "Unknown" Format from a DVD
By Hombre7 in forum Newbie / General discussionsReplies: 7Last Post: 11th Jan 2009, 13:14 -
DVD with menus, replacing "bad" video with "good" video
By chipsndukes in forum Authoring (DVD)Replies: 34Last Post: 4th Dec 2008, 18:45 -
S-Video capture produces "crosshatch" noise
By scootdogg in forum Capturing and VCRReplies: 11Last Post: 4th May 2007, 12:53
