So know that I have joined the sacred halls of VCDhelp, I was wondering if anyone has a little program to do batches of video conversions under TMPGenc? I have a ton of Family Guy episodes that I would converted to VCD but don't want to have to manually start each conversion--Any help for the uneducated plebe would be appreciated![]()
Here's what you need to do for TMPGEnc Batch Encoding
1. Load the appropriate TMPGEnc template.
2. Select the Video/Audio files as usual.
3. Select the output file name as usual.
4. Hit "cntrl-s" to save this as a project. You'll
be asked for a filename when you do this. This
is a .tpr file you will create.
Do this for *each and all* of your selections
so that you will have a bunch of .tpr files saved; one
for each selection.
Next hit "cntrl-b" to bring up the batch-encoding
dialogue box. Click "Add Job" and select all of your
.tpr files. They will show up in the window when
you've made your selection.
Next hit "Start" - that will start the batch job.
TMPGEnc will encode all of the files in batch mode.
Hope this makes sense, I know it is not intuitive,
I had to figure this out for myself and am happy
I can explain to someone else....
Thanks,
vcddude
PS This question comes up a lot, maybe it should be added to the TMPGEnc How-To sections?
Will this also split the MPEG to fit 2 CD? In other words when I load the Video and Audio that was generated by DVD2AVI is there any way in this batch process to tell it to split to two or even three files for burning? This would save a lot of time. Many thanks in advance
Bud -
Bud,
You do the same batch process described and set the range of the encoding using Setting-> Advanced-> Source Range (double-click). A number of users don't realize that "Source Range" exists. Just give your two output files different names so that the second doesn't write over the first. -
Thanks for the quick response, I have used the Source Range for cutting and encoding but did not know about the batch method, that will work great, again many thanks......
Bud -
Wow--Its like a borg collective in here. Thanks for the info (thats to everyone above especially vcddude) I will try it out tonight and see how it goes.
<font size=-1>[ This Message was edited by: menace on 2002-01-10 13:46:28 ]</font>
Best way to batch convert xvid/avi files to mkv/x264 files?
By gaikokujinkyofusho in forum Video ConversionReplies: 1Last Post: 13th Jan 2012, 06:31 -
Tmpgenc Plus & TMPGEnc Batch List Creator help Please
By VOYAGER2009 in forum Video ConversionReplies: 2Last Post: 4th Jul 2010, 07:57 -
How to batch encode with TMPGEnc
By BonnieW88 in forum Video ConversionReplies: 8Last Post: 20th Feb 2008, 20:52 -
TMPGEnc Plus won't complete batch jobs.
By Timex in forum Newbie / General discussionsReplies: 2Last Post: 6th Dec 2007, 23:13 -
Batch tag WMV files?
By xxsunshinegodxx in forum Newbie / General discussionsReplies: 0Last Post: 17th Sep 2007, 12:27
