Hi
I have a Pioneer DVR-530 H-S DVD hard disk recorder. I've had it for about a
year (just out of warranty) and it is now temperamental with the Gemstar
Guideplus EPG recordings and saving the title of the recording.
Guideplus still works with showing the programme guide, but what fails to
happen everytime now is that the title is not taken from the guide, it just
leaves a blank title. And I really want it to save the title, it's a pain to
enter manually, particularly as the EPG has been downloaded with the info.
I also noticed that when this happens, after I use the Guide and hit the red
button to record a show, then go to the Schedule, it shows the recording listed
but instead of the title, it shows the channel logo.
The fact it shows the channel logo rather than the title in the schedule,
makes me think it is designed to do this and maybe I have changed some
setting. However I can sometimes switch on the Pioneer and it will work as
expected and save the title with the recording, other times and more often
than not now, it doesn't.
I have defraged the hard disk and entered in my postcode again to refresh
Guideplus, but it's still not working properly. I've searched the forum and
can not find anything like this mentioned before, but hoping someone knows what
is going on!
thanks
Richard
I've since found out that entering titles manually before the recording starts in the Schedule doesn't work either.
It lets me enter the title, then briefly shows it in the Schedule, but flicking from one recording to the next, the title disappears to be replaced by the tv channel logo. Very annoying.
I can now only label recordings after they have been recorded. Any ideas how to fix?
Cheers
Rich -
Hi
What firmware version do you have? -
Unplugging from wall for a few minutes resets dvdrecorders, computers, tvs, etc. You could try that.
Also consider that it's not your machine but the guide data is not coming in & this usually self corrects when they straighten it out. -
HiOriginally Posted by Hkan
Version 3.33
SYSCON:RELEASE_159
TUFLCON 835.000
DRIVE 1.52 *
DEVICE:PRISM2 ES2
REGION 2
You sent me the latest firmware, but I'm nervous trying this unless a last resort.
Also, is there an md5sum checksum on the Nero image so I can verify all okay? I'm using Linux and will need to convert the Nero image to iso, but for peace of mind, do you have md5sum to double check before I use it?
thank you
Rich -
Ah OK
For the Nero file:Pioneer_DVR530-630H_3.53.nrg
MD5: 9B8ABA3B2CA7E642D0B63DC61E3F06E0
SHA1: C35488F2BBD6FF485CF037C468FC5A951297FCCA
RIPEMD: 1D8738E6CB460C85D08DD03B8645AB0980BF6127
The files inside the nrg , ie when you have them on a CD:
sr05_W353_r9r159_t855[1].2.4_i101.bin :
MD5: 03CDB900D177653D9ACD801F6EBD3854
SHA1: FA9F3D6221120FC2279A99C881AEA446D4FC51FA
RIPEMD: 56399292712E25C356F752B5E21479A15696575E
tfd05_W353.bin :
MD5: EADAD80CD0FE7A0D8941F7AB0CC27C39
SHA1: 60F6DB8AFAAD681AB3283E77162DEFDAEC4CAC2A
RIPEMD: CBFD5DFBA1D6E9C99EAC8C1EC01317FC357B34D0 -
Shoot, it's now happening to me & I have a Panasonic. Therefore its their new guideplus software update I bet. Happened before with another update they did.
Therefore, not your machine. Shoot, I hope they get back to their old guide plus software.
Did you notice in the data field that they show if a show is a repeat or not now? So they have changed their software.
To correct it, just unplug your machine for a minute & plug back in.
Hard Drive upgrade for Pioneer DVR-530/630H
By Hkan in forum DVD & Blu-ray RecordersReplies: 55Last Post: 22nd Aug 2012, 02:07 -
Pioneer DVR-660H Problem Recording to HDD
By det bullitt in forum DVD & Blu-ray RecordersReplies: 0Last Post: 14th Aug 2010, 13:22 -
Need help with Pioneer DVR 220S Intermittent recording problems
By horhota in forum DVD & Blu-ray RecordersReplies: 6Last Post: 3rd Nov 2009, 07:27 -
Pioneer DVR-530 disc tray doesn't open
By Alex_x in forum DVD & Blu-ray RecordersReplies: 3Last Post: 22nd Sep 2008, 17:39 -
Pioneer DVR 630 HS - Recording will not playback
By ktmsprocket in forum DVD & Blu-ray RecordersReplies: 3Last Post: 14th May 2008, 13:06
