Hello,
After capturing the video from my camcorder (Panasonic GS300), the quality of the video is not good. Every time that there is movement on screen, it covered with thin stripes horizontally.
When the the video is still it looks OK.
I tried viewing with different players but all show the same result.
Thank's for the help.
That's Interlacing. What you are seeing are the ODD and EVEN fields interacting with eachother.
Search for the subject as there is alot to learn abuut it. I am not expert so I cannot tell exactly why you may be seeing it on your screen. On thing I know is that it will probably not be apparent once viewed on the TV set.
It might be something on the interlaced / uninterlaced settings while you were transfering to the PC.No DVD can withstand the power of DVDShrink along with AnyDVD! -
in short:
It's normal. Don't worry about it. If your destination is DVD then it can stay just how it is.
Otherwise you may want to de-interlace. -
Yes, this is working but not with "BOB" (the video is not running smoothly, it looks like it is "shivering"). The best option is "Blend".Originally Posted by jagabo
Another thing is that there is a message in the beginning that "the video is broken".
Any ideas ?
Poor Picture quality - need help!
By Martin747 in forum EditingReplies: 2Last Post: 26th Dec 2010, 13:00 -
Poor Burning Quality
By CindyLuB in forum DVD RippingReplies: 6Last Post: 17th Jul 2010, 21:41 -
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 20:23 -
Poor Video Quality
By itsernst in forum Capturing and VCRReplies: 20Last Post: 10th Feb 2010, 17:32 -
Poor Quality
By Net_Bug in forum Capturing and VCRReplies: 3Last Post: 29th Mar 2008, 17:37
