Using DVDDecrypter, I converted a home DVD with menu to an ISO file. I will use DVDDecrypter again to write on the DVD-R, but how can I add additional clips so that menu will still work? Thanks.
Extract the video_ts from the iso using isobuster or daemon tools.
With dvdremake pro might you be able to add new clips and keep the old menu...
Or just reauthor and make a new menu using tda, use add dvd-video to add the dvd clips from the old dvd(not any menus). -
Thanks.
Since I'm not wanting a seamless merging, I thought I can just add a movie clip or a vob file and it will play after the original movie ends even though there is a pause in the transition. This is a wedding video and I might get killed if I delete the neat menu. I will take a look at your suggested trialware. -
Hi-
Extract the DVD as Baldrick said. Author your closing clip to DVD. Use Muxman on the audio and video if you don't know how, or if you have only a vob, use IFOEdit to make a real DVD out of it (up at the top, DVD Author->Author New DVD). Open the original wedding video in PGCEdit. Highlight the main video in the left screen. Up at the top go Title->Import Title's Closing Clip. Follow the easy directions from there. Save and Test. If you screw up somehow (nearly impossible), PGCEdit will have saved the original IFOs which you just replace and start again.
It'll retain the original menus and everything else.
Ulead Video Studio 11 - how to add multiple sub and more movie clip
By mic2x in forum SubtitleReplies: 0Last Post: 27th Aug 2008, 13:52 -
Trying to add a small intro clip to a movie file without re-encoding
By solar2504 in forum Video ConversionReplies: 11Last Post: 19th Mar 2008, 10:19 -
By solar2504 in forum Authoring (VCD/SVCD)Replies: 1Last Post: 18th Mar 2008, 02:53 -
How to add an age clock to the movie clip
By iho in forum EditingReplies: 3Last Post: 2nd Nov 2007, 04:42 -
What is the easiest method to add intro clip on DIVX ?
By rob3rtz in forum Newbie / General discussionsReplies: 3Last Post: 7th Oct 2007, 05:35
