  1. Member wwaag's Avatar
    Jan 2002
    Olympic Peninsula, US
    This is totally weird. I cannot enter any information from the keyboard when using Internet Explorer. In fact, I had to use another machine to make this post. I was able to enter the forum, select the sub-forum and successfully left-click the "Add New Topic" button. I then go to the "Subject" box, left-click again and nothing happens. Usually, the cursor appears. I just did a virus scan using Zone Alarm yesterday. Mouse/keyboard functions are OK with internal apps like Notepad. Any ideas? Thanks in advance.
    wwaag
    I just installed Firefox and it works OK. Maybe one of the recent Explorer updates is the culprit. Really strange.
    Oct 2005
    666th portal
    i'd be really wary. it could be a trojan or keystroke logger intercepting the input. check all running processes and run some trojan detection software.
    haven't heard of any problems like this from an update.
  3. Member wwaag's Avatar
    Jan 2002
    I've redone the virus scan and also a couple of different spyware scans. Nothing.
    wwaag
