Sorry if this is a newbie question, but I'm trying to insert deleted scenes into a dvd. The movie is 16x9 with 5.1 ac3 audio. The deleted scenes are 4x3 with 2ch ac3. TDA won't add them together because the aspect and audio are different. What's the easiest GUI freeware solution (not using a dvd recorder) to convert the deleted scenes so they appear compatible with the movie?
If you add the clips to a new track in TDA it will work...but you probably want them in same track.
I don't know any easy GUI solution to convert to 5.1 ac3, maybe super or mediacoder. And you need to crop or resize the image to get correct 16:9...if you just set it 16:9 it will look stretched..
Changing aspect ratio for WMV?
By vato76 in forum Newbie / General discussionsReplies: 3Last Post: 4th Feb 2010, 09:27 -
Changing a DVD's Aspect Ratio
By soneman in forum Authoring (DVD)Replies: 11Last Post: 8th Sep 2009, 18:18 -
Changing aspect ratio.
By Lyceum in forum EditingReplies: 5Last Post: 28th May 2009, 12:19 -
Changing aspect ratio?
By Marlow in forum Video ConversionReplies: 2Last Post: 5th Apr 2009, 05:40 -
Changing an aspect ratio on DIVX
By diablo_jones999 in forum Video ConversionReplies: 13Last Post: 29th May 2007, 11:53
