Having the same problem as Quiffster, except it's with every audio file I try to load in to the program - MP3, MP2, WAV, you name it! No matter what file I try to load, as soon as I hit Convert or try to move the slider bar, I get RUNTIME ERROR '6' - OVERFLOW.
Using the latest v0.1.9 beta, have tried installing DAudioK twice (first time was just the RAR download, copying the files straight over).
Windows Vista, Core2 DUO.
Any ideas?
Results 31 to 50 of 50
Bump.
Been three weeks since I posted my question ... would be gratified if the author could address it (notice he hasn't posted to this thread since 28th June - almost three months). -
I'm sorry.
My real job is been keeping me very busy.
Are you running DAudioK as administrator under Vista?
thank youMy oppinions may change, but not the fact that I am right!
www.rockassoftware.pt.vu
DAudioK => https://forum.videohelp.com/viewtopic.php?t=306886
DVD Rebuilder
http://dvd-rb.dvd2go.org
http://www.jdobbs.com -
Yes, I have run it both as User and as Admin; same error either way each time. When I start it as Admin though, I get warning from Vista that Console-based Script Host has been closed to protect my computer (Data Execution Prevention alert). When I try to run it in Compatibility Mode (WinXP or Win2000), it crashes at the point where DEP would otherwise close Console-based Script Host, before the GUI appears.
Makes me wonder if DAudioK isn't writing to areas of memory it isn't supposed to (at least in Vista). -
QUOTE:
"Any news on the problem converting DTS to AC3 whereby the centre channel (speech) ends up coming out of the right speaker? Would be great if this issue could be sorted out "
Just tried to convert DTS for the first time. And I got the exact same problem when converting the DTS to 5.1 AC3, as I quoted above. Any help would be appreciated. Thanks. -
had it runnin under xp but had to reinstall the system and now I'm gettin that runtime error6 also. Don't remember if I had a earlier version or 9 but hopefully a solution can be found soon.
I am also getting the Run-Time Error '6' Overflow. I just downloaded this program and am trying to use it for AAC multichannel to AC3 multichannel conversion (as I haven't found any solution which works for large movie soundtracks yet, no matter what the platform.)
I get the error no matter what the output it; My input is various different AAC 5.1 multichannel files. Other input formats seem to work, including two channel AAC (in the iTunes .m4a format), except when I get errors regarding AVISynth - but I'm not interested in that, so let's focus on the fact that I'm getting different symptoms from others who have posted with this Run-Time Error '6' in that it happens when I hit the "Convert" button -or- try to play only an AAC multichannel source file.
Also- I am NOT using Vista, but rather WinXP Pro SP2 (either in virtualization via VMWare Fusion, or natively via Apple Bootcamp.) My machine is a Core 2 Duo iMac.
I'd gladly donate towards getting rid of the cause of this error if it means I can actually convert from AAC multichannel to AC3 multichannel. I also agree with previous postings about the need for the ability to assign the channels, as AAC doesn't actually have a definite standard channel order.
In the meanwhile, I'll have to toss this program into the large growing pile of apps (or combinations of apps) which just don't seem to be able to help me convert AAC multichannel to AC3 multichannel. -
Just hit the play button (note: does not seem to have any obvious effect) before you hit convert, it should work.
today I try one software
delaycut... http://jsoto.posunplugged.com/audiotools.htm
I got this problem too
but the problem is solved now
1. download the delaycut
2. fix the .DTS file
3. the message never appears and the conversion carry out smoothly
To get rid of the overflow error just install the latest k-lite codec pack en select all codecs. After that the program will work without errors.
that doesn't work for meOriginally Posted by amai
any way to fix this "runtime error" problem?
i'm using the latest version and trying to do ac3 > ac3 and dts > ac3 -
the one I used is "klmcodec385.exe". while installing I selected all possible codecs, so I don't know which one is responsible, but it worked for me.
The solution to your problem may be as simple as RENAMING the extracted audio file extension from AAC to DTS.Originally Posted by zzipp
After having tried all kinds of codec packs and transcoding combinations myself, eventhough to no avail, I've found out that when a native .dts file is given an .aac file extension, it causes DAudioK to assign a NEGATIVE duration to it (hence the overflow error). After renaming the file to .dts, the error simply disappears along with the negative duration bug and the transcoding works like a charm!.
Been there, done that.
I hope it helps. -
Hi everybody.
I'm sorry for this long time away. Real Job has been a pain in the ass, plus some personal issues plus windows vista kept me away from releasing a new version for this long.
Anyway, I am working on DAudioK again just been delayed a bit because to fix the Vista compatibility problems, I had to own Vista so... I am running first tests right now so I hope i can make it work, even if some bugs may remain unsolved for now they will, as possible be fixed on next releases.
Thank you all for your patience. i will try to do my best and as quick as possible.
RockasMy oppinions may change, but not the fact that I am right!
DVD Rebuilder
Hello,
I get the overflow error too,when im trying to convert dts to ac3....
I also tried to install the k-lite codec pack, but still the same prob.
I got windows vista, maybe someone knows already how to fix this error.
thanks in advance -
I just downloaded DAudioK to do a comparison between its upmixing capabilities and BeHappy's. Unfortunately I'm getting the Overflow (Run-Time Error '6'). Vista Core Duo.
Another problem I'm having with it is that it fails to detect my Internet connection (I promise you I'm typing this on the same computer
). That'd be a handy way to check for an update that fixes this problem, but it's a little Catch-22 at the moment.
I'm still very interested in testing DAudioK, but in the meantime for anyone looking for a fairly easy to use app that will upconvert, try BeHappy. NB: you'll have to have Avisynth installed, and you'll need soxfilter.dll in Avisynth's plugins dir, and if you want AC3 you'll need aften.exe (and maybe associated files) in BeHappy's encoder(s) dir. I just copied them over from meGUI. There are guides out there. I've successfully converted some movie soundtracks from pretty poor 2-ch AAC sources (extracted/encoded to WAV using Any Audio Converter; great little app) to AC3 5.1. They now sound *much* better on my 5.1 speaker setup with my A/V recevier decoding. -
Hi everyone!
It was a long time without getting my hands back to DAudioK... well... it's time to get back on "business"
From today on, I will be looking for alpha/beta testers to get the application back on tracks, specially when it comes to Vista and Windows 7.
So, please, if you are interested on some pre-release testing, sign in on this thread at my site Here.
As it is easely understandable, after 2 years and a half with little development, it will be a hard task to get DAudioK work flawsly in a short term, but I hope that with your testing and feedback we will soon have a functional and improved version.
For the time being, my time will be "concentrated" on the feedback from the testers that sign in the topic I posted above so I don't keep jumping from forum to forum wasting precious time. After the next release, everything will be back to normal including my daily "forums marathons"
thank you for your time and collaboration.
ps. just in case... the word "business" posted above is between "quotes"... DAudioK will always remain free as it always was. Thank you
DVD Rebuilder
Runtime Error '6'Overflow on DAudioK
By FatalX in forum AudioReplies: 0Last Post: 15th Oct 2010, 09:27 -
DAudioK gives me an error messeage
By Belfour in forum AudioReplies: 0Last Post: 4th Jan 2009, 14:50 -
DaudioK software error
By volam in forum AudioReplies: 3Last Post: 6th May 2008, 10:13 -
Need Help converting DTS to AC3 5.1 Using DAudioK or Similar?
By neo_74 in forum AudioReplies: 1Last Post: 1st Jan 2008, 15:53 -
Some advice about Prevx and my DAudioK
By Rockas in forum Off topicReplies: 2Last Post: 13th Jun 2007, 17:14
