I am using a program called VHSToDVD to transfer a lot of my old videos to dvd. but after I have converted movie from mpeg to dvd vobs it plays like frame by frame not right slow I mean, but its a bit hard to describe but people move in so many frames a sec its not right slow but, not as a normal movie. bit like slow motion. if say I was doing any other thing on pc whilst I was copying from VHS to pc would this have done that. as I am sure I wasnt. I cannot remember if movies played ok before conversion which I used convertxtodvd or maybe there is a better program to convert.
Isolate the links in the chain until you find the culprit.
Here's some random questions I have. I've answered as many as I can myself but need some help filling in the blanks
What software are you using to get the VHS file onto the computer with ?
VHSToDVD
What hardware are you using to get the VHS file onto the computer with ?
What format is it capturing to on the computer ?
MPEG
Does it play back smoothly ?
Any indication of dropped frames ?
What software are you using to convert to DVD ?
ConvertXToDVD
NO
Are you testing playback on a PC, or on a DVD-Player ?If in doubt, Google it. -
First thing
Disable any running task that dose not need to be running in the background ... ctrl + alt + dell ... only once ... twice reboot's pc .
Knowing what to disable is for most a trial and error ... just dont kill off "system" listed item's .
Thing's to kill off :
Quicktime
Itune's
Epson , hp ... ect ... printer , camera app's ... if device is not connected ... they shouldn't be running until needed .
Incd
Norton's av ... get avg ... it's less of a resource hog ... there's a free version available .
If you see "wowexe" or something similar ... it's called by old scanner , printer program's ... kill it right off .
Msn messenger
Yahoo messenger
Outlook express , if it's running
Any listed spam tool's
Could be other's .
Kill off "screen saver"
Kill off "power management"
Scandisk hd
Defrag hd
Scan pc for virus's
Scan pc for crapware using ad-aware se ... quarantine anything it list's .
Do not use computer when capturing ... set and let it do the job .
Now try again .
According to you pc spec's ... you should not have any problem's ...
If killing of non-essential running task's dont make an improvement ... then there is another problem -
ok jimmalenko I will try this but I have a feeling it maybe to do with me doing other things on pc whilst using VHSToDVD program. or maybe using convertxtodvd which i dont think so. I use a scart lead plugged in back of video, which has 2 leads from that audio, and video the video 1 go into my tv card video port, and audio into my sound card. but i have beed told you can buy a special lead from video player to pc usb port and in between is a box which do it all check this web page
http://www.aver.com/2005home/product/videocapture/ezmakerusbplus/ezmakerusbplus.shtml
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 10:21 -
How to convert a PAL VHS into NTSC VHS or DVD?
By coody in forum Video ConversionReplies: 9Last Post: 22nd May 2011, 03:09 -
VHS to DVD - LongPlay VHS Problem
By zanzi81 in forum Capturing and VCRReplies: 14Last Post: 1st Feb 2010, 02:56 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 15:25 -
NTSC VHS to PAL DVD Via DVD VHS Combi
By wozmac in forum DVD & Blu-ray RecordersReplies: 7Last Post: 6th Jun 2007, 02:16
