hey all
im in the process of converting a avi to dvd usuing convertxtodvd
and in the folder it has audo_ts video_ts folders
my question is can i just drag and drop them into nero when burning the dvd or do i have to do something special to make the dvd a "dvd" if you know wat i mean
Results 1 to 19 of 19
If you are burning with Nero, open the Burning Rom module, select DVD Video as the template, then drag the contents of the Video_TS folder that ConvertXtoDVD made into the Video_TS folder in the template. The Audio_TS folder is empty, so don't worry about it. You are now ready to burn.
Read my blog here.
https://www.videohelp.com/guides.php?howtoselect=3#3;25
My preference is to use Nero Express:
http://members.dodo.net.au/~jimmalenko/NeroExpress.htmIf in doubt, Google it. -
thanks 4 that
i was planning to use express
will that keep all the chapter and menu etc? -
Originally Posted by krayzie
/Mats -
Or there's folder2iso, imgtools classic .... and probably a couple I've missed ....If in doubt, Google it. -
I believe that folder2ISO is not recommended for DVD Video, but is fine for making ISO for data discs.
Read my blog here.
/Mats -
well it worked guys the convertxdvd is great
but soem reason the main menu didnt work
soon as i put it into the dvd player it started 2 play the move..
so i dont know what went wrong -
There is a check box in the Authoring section of the ConvertXtoDVD to get the menu to fire first.
Read my blog here.
Audio_TS & Video_TS what they mean exactly?
By Deadmoney in forum Newbie / General discussionsReplies: 5Last Post: 4th Oct 2011, 11:31 -
AVI to DVD -didn't get video_ts or audio_ts
By Ursula514 in forum ffmpegX general discussionReplies: 5Last Post: 8th Jan 2011, 14:31 -
Copying a Recorded DVD--Video_TS and Audio_TS
By solarblast in forum DVD RippingReplies: 14Last Post: 23rd Jan 2009, 07:41 -
Another folder than Video_ts and Audio_ts
By claudiofran in forum Authoring (DVD)Replies: 12Last Post: 3rd Mar 2008, 13:39 -
How do I rip DVD to VIDEO_TS/AUDIO_TS folders?
By Crimea in forum Newbie / General discussionsReplies: 6Last Post: 18th Feb 2008, 11:34
