Hi
Well i have used HDTV2DVD to convert my .ts file to mpeg. It works great butr it converts it to NTSC and i want PAL really! There is no way to change it. Are there any other programs i could use? Is anyone aware of any NTSC>Pal conversion without wobbling or jerking???
Thanks in advance
M
Results 1 to 20 of 20
...and what did your searches for "NTSC to PAL" turn up?
/Mats -
Well i was hoping there was a program to convert.ts straight to PAl?? any takers?
convertxtodvd ? maybe not the best method for ntsc to pal...but it supports ts.
use DVDPatcher it works a treat for me
https://www.videohelp.com/tools?tool=DVDPatcher -
Lets start again. Can anyone reccomend a programe to make.ts file straight to PAl mpeg2?? That way i dont have to convert NTSC to PAL! Thanks
There is no "holy grail" application for converting video between TV systems. Not when going from one format to another - not when keeping the same format.
Bite the bullet, search and read. The issue has been beaten to death already.
/Mats -
No no you missundderstand. I have some PAL .ts files that i want to make into mpeg2 s. The only software i can find that is any good is HDTV2DVD. This converts to NTSC though! I dont want it converted i just want it to make a PAL mpeg. THat program does not allow you to do PAl only NTSC. Surely there is a program that allows a PAL .ts to convert to a PAL mpeg. Its silly for me to convert it to NTSC for no reason!!
OK - Sorry! Well, I'd think manonos suggestion would work?
But then again - I'm pretty confident HDTV2DVD does PAL too - I'd be surprised if CrissyBoy made a NTSC only app.
Check this thread:
https://forum.videohelp.com/viewtopic.php?p=1377306#1377306
/Mats -
Welcome to reality!
/Mats -
So there's no conversion necessary? Your source is PAL and the destination is PAL? Then why:
Anyway, I don't think you've done it using AviSynth yet. Or at least not done it right. -
Ill try that! I dont need an NTSC to PAL conversion. I exp it wrong sorry!!
Originally Posted by mats.hogbergSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
But CrissyBoy! You disappoint me!
/Mats -
Why Can't I convert the whole file in mpeg streamclip?
By alphonsecpone in forum Video ConversionReplies: 0Last Post: 5th Mar 2011, 09:24 -
How do I convert a HD MPEG-2 file to MP4?
By Newtype in forum Video ConversionReplies: 4Last Post: 2nd Feb 2010, 00:11 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 07:30 -
convert hd pal mpeg2 file to hd ntsc mpeg2 file
By gearo in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 5th Jun 2008, 01:12
