after loading a mkv file to vdub mod i get an error saying "only handle [s_text] subs for the moment" is there another program or way to convert the video file? i want it to avi
When you first run VDubMod you get a popup warning that its mkv support is out of date. It suggests mkvtoolnix, which would be my suggestion to. It is basically the reference matroska software. You might also want to check out mkvextractgui to make extracting streams easier.
And besides, it just won't convert the subs. Save As AVI should still work.
VDubMod doesn't support muxing subs to avi at all. Only mkv and ogm. If you want to mux subs to an avi, you would need to use AVI-Mux GUI and you need to OCR the vobsubs with say SubRip first.
Simple guide for Virtual Dub Mod 1.5.10.3
By s_joy09 in forum Newbie / General discussionsReplies: 35Last Post: 31st Jul 2010, 16:33 -
Virtual Dub Mod video combining?
By wcdeich4 in forum EditingReplies: 1Last Post: 18th Dec 2009, 08:18 -
Virtual Dub Mod Saving Problem
By cdgfx84 in forum Video ConversionReplies: 2Last Post: 1st Sep 2008, 14:08 -
Queue files in Virtual Dub Mod?
By leogeo in forum Newbie / General discussionsReplies: 2Last Post: 2nd Nov 2007, 03:13 -
Virtual Dub Mod
By OG24 in forum Newbie / General discussionsReplies: 11Last Post: 8th Aug 2007, 16:36
