DOS is still alive and well today. You can burn cd's and even use usb drives in DOS thanks to newer drivers that have been written. I made an all DOS box for a guy's business because the software he used was still DOS based and the newer version would cost $2500! All you need is a pretty little menu driven dos box and you can run your programs, perform backups..etc.
Results 31 to 57 of 57
my most preferred DOS command:
format/q C:
............ just kdding
My most widely used DOS command: DIR to see what in the current directory.
Although Windows seem to dominate the PC world, I still use DOS (by open one or several DOS windows) at work. The advantage of DOS over Windows is I can write .BAT ( batch ) files to automate repeatitive tasks. Instead of clicking the mouse like a mad man, I simple invoke the batch file and go take a coffee break while the computer is carrying out the tasks.
Not only that, I also wrote lot of software tools running under DOS. Windows is nice if you like to the mouse.ktnwin - PATIENCE -
Originally Posted by Shaky Jake
"exit" works in linux too, but only to exit the shell.
Then you need to get serious about shutting the sucker down. It will resist. You must be resolute. -
DOSKEY has been good...
Still use SUBST, especially for quick autorun checks before burning.
FC is still handy.
Piping through MORE was great for any CL app that spit out more info than 1 page's worth...
Scott -
I used to be able to write DOS bat files that would make a text menu where you selected by number to load files. A bit like Windows without the GUI It has been so long I cant remember how to do that anymore.
I did get in trouble at my school once when I created win.bat that only had @echo off, nothing else. When someone tried to start Windows 3.x, nothing would happen at all. Since it was hidden inside Windows directory, most people didn't know what was wrong and never noticed that win.bat is not part of standard Windows set. -
Originally Posted by isogonic
Don't understand why people talk about "dos" commands as they were in the past. A lot of things are a lot faster from the command line that they are from the GUI. Some people have mentioned the batch renaming of files as an example.
Other good things are:
rd /s /q <directory> (or RMDIR if you prefer) it is instant, which is not the case if you delete a deeply nested directory with a ton of files in it, from the GUI
cygwin (well, not a dos command, need to install cygwin, but it gives you a proper "find", "ls" etc) far better than WinXP commands.
The favorite (apart from cygwin) is
pushd <dir> and popd
Can't move around the directory tree without pushd and popd. A lot of people do not know them.
C:\> pushd \Program Files
C:\\Program Files> pushd c:\Data\Stuff
C:\Data\Stuff> pushd C:\Documents and Settings\Me\Desktop
C:\Documents and Settings\Me\Desktop> popd
C:\Data\Stuff> popd
C:\\Program Files> popd
C:\>
Excellent stuffTerje A. Bergesen -
Originally Posted by jimmalenko
There are things you can't do at windows. There's a command (cacls) can change files and folders permissions in a way that windows don't allow. Try to add permissions to a new user in a folder without change the other users' permissions when children folders have different permissions than main one. That's only possible with cacls. -
Useful for me when I am creating cuesheets for burning audio CDs (I like to add CD-text), i use the command:
dir *.flac >temp.txt
Then I can take that temp file into a text editor and create my cuesheet from there.
Darryl -
As in, "format /?" or "dir /?" when I can't remember what switches do what.
EDIT: Oh, and not really a DOS command per se but I use "sysprep.exe -bmsd" all the time! -
I'd go with debug. Many is the small utility I'd hand assemble in debug and save for future use.
Memorieeeeeeeees!
Fdisk /mbr
Format c: /u /s
Ping (insert address) -t
tracert (insert address)
chkdsk
deltree
hmmmm.... I LOVE THEM ALL!!!!1f U c4n r34d 7h1s, U r34lly n33d 2 g3t l41d!!! -
You know if I had a 4 port kvm instead of a 2 port I think I'd build me a DOS box...
dir /p
format c: /s
path=
rd
Also, some damned low-level format command that I used to use on bad 20meg hard drives when they started to go south. Can't remember what it was --- too many years ago and I'm too old..."I'm sick of paying for dinner and being served cowshit, while they give the bums eating out of the garbage my meal."
--- D. P. Smith -
/hdir
Was a hot directory, it showed you /dir but all the different file types were a certain color (green/blue/red/purple, the basics). Was awesome!
http://www.animatedsoftware.com/faqs/learndos.htm#vital_hdir
Rip the music from your favourite playstation 2 game
By CGar in forum User guidesReplies: 9Last Post: 18th May 2018, 12:50 -
Command-line command for fixing AVI?
By timur in forum ffmpegX general discussionReplies: 1Last Post: 23rd Sep 2009, 02:23 -
MPEG1 -> MP3 conversion possible in DOS?
By Figge in forum Video ConversionReplies: 3Last Post: 25th Mar 2009, 08:05 -
Question about certain dos commands
By jimdagys in forum ComputerReplies: 35Last Post: 15th Oct 2008, 22:57 -
What's your favourite new MP4 player?
By NG in forum Portable VideoReplies: 0Last Post: 18th Sep 2007, 05:56
