Hi everybody:
After a research I see that there are many ways to convert audio on a AVI from AC3 to Mp3 or WAV.My question is what's the easiest way for a dummy like me ??And perhaps the faster.!!
hilario.
Results 1 to 23 of 23
The easiest, once you have VirtualDub setup to read AC3 audio, and to encode to MP3 audio, is to load the AVI in VirtualDub, set video to direct stream, set audio to full processing (and select and configure MP3) and just save AVI.
/Mats -
Tks for yr prompt reply mats:Originally Posted by mats.hogberg
Yes I have virtualdub, but How do I know if I have the set up to read and to encode ac3 to mp3 ??
On audio I see only 3 options : no audio , source audio or WAV.And just in case I dont have how can I add that to virtualdub??
tks.hilario. -
By reading guides for VirtualDub. Basically load the AC3 AVI. If VirtualDub doesn't protest - You're fine on that respect. If not, look here:Originally Posted by hilario
https://www.videohelp.com/tools?tool=AC3_ACM_Decompressor
For VDub MP3 encoding, you need this:
https://www.videohelp.com/tools?tool=Lame_MP3
/Mats -
Well, I found some problems:
1- I think my VD has the ac3 codecs as it's not "protesting"
2- Downloaded Lame_mp3 but after extracting all files I dont see any LameACM.inf (vers. 3.98 6 !!
3-On the other hand I can't find anything to enable that codec on my VirtualDub !!
hilario. -
Well, try the third link on the download page:
http://www.rarewares.org/files/mp3/lameACM-3.98a6.zip
It sure has a LameACM.inf file...
/Mats -
Yes I did it and its installed (listed on GSpot codec)Originally Posted by mats.hogberg
Now when I follow all the steps om VD:
Video >direct stream copy
audio> full processing mode
open file > save file = VD ERROR: no audio decompress could be found to decompress the source audio format
source format: tag 2000)
What am i doing wrong now ???
Sorry to bother you with all these problems.
hilario. -
You don't have the AC3_ACM_Decompressor.
/Mats -
WOW.... mats
You saved my day.
It works now.
many thanks.
Just one more thing.
I noticed that there are lots of codecs (audio and video) instaled on my machine.
This may sound stupid but there will be no imcompatibilities with all that stuff ??
And if the answer is perhaps , how can we find out what are the incompatibilities ??
What are the most common codec that one needs to have installed ??
tks for your help once again.
hilario. -
Some codecs are required by windows, so if you don't have problems (crashes, errors, etc.) I would leave them alone. If you installed any codec packs you could try uninstalling them, but that may also cause trouble (some uinstallers don't do a good job). Rule of thumb, if it isn't broken, don't try to fix it.
Just remember, codec packs are more trouble than they are worth, you are far better off installing indiviual codecs only on an as needed basis. Such a practice can save one from much grief.Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think. -
Hi Skith:
Will follow yr advice and leave things as they are.
tks.hilario. -
Hi fellas, great great forum, even for the 'ignorantus maximus' species like myself!...
Now, I grabbed VirtualDub and have been converting my AVI's sound to MP3 -since I cannot reproduce them with sound when in AC3 through my iZak.
I'll tell you though, it is either way too much work to do 50-60 AVIs one by one, or I am lazy -a little bit of both maybe?
Now, anyone can take me by the hand to tell me how to run these 50-60 (an growing AVI's) in a batch routine (only change required here is AC3 >>> MP3, I leave video on 'Direct Stream Copy'). I have gotten my paws on DubMan and on VDBatch, but somewhere between trying to create .vcf, .jobs and trying to apply them to a batch of AVIs I have messed my few brain cells up...
So... all ears! -
Try this: Use AVI_GAIN_REGULAR.BAT
https://forum.videohelp.com/topic314909.html
If you have trouble, try the beta
http://www.mediafire.com/file/kbyyb3gxszj/avi_gain_v08_BETA.zip -
Grrr. I've tried installing the AC3 ACM Decompresser but VD keeps throwing up the same error as described earlier in the thread......
ow long should the decompresser take to install? Because when i install it, the install screen flashed up for only a split second, not long enough for me to be able to tell if it's actually installed or not. I'm running W& 64-bit, would that be causing me the grief here?Video >direct stream copy
thank you very much now it works
ok I got one more question sorry:
I am converting to mp3 beacuse my dvd usb mode wont play the AC3
my question is if I compress to Lamemp3 will I be able to play on my dvd
or should I just go with regular mp3 conversion?
thanksLast edited by Kayfc; 15th Jun 2011 at 16:10. Reason: now not no :P
for some reason my lg dvd player and or tv cant play the video in usb mode after i converted the audio to mp3.
OK so I tried and converted to mkv didnt even detect file. Tried .avi didnt load.
So after checking the divx page for my dvd player(LG dv556) and my LG tv(42PJ350R-MA)
my conclusion is that the resolution of my video is too big for my devices to play
I still learned a few things. thanks for the help: Baldrick & aedipuss
Converting AC3 in a video to MP3
By LittleJohny in forum Video ConversionReplies: 4Last Post: 4th Jun 2010, 20:21 -
Audio out of sync after converting AC3 to MP3 in AVI with VD
By huykin in forum AudioReplies: 6Last Post: 1st Oct 2009, 13:27 -
Trouble converting AVI(divx)+MP3 to FLV+MP3
By BLboy in forum Video ConversionReplies: 7Last Post: 21st Jul 2009, 04:36 -
Converting an AVI video with AC3 audio to an AVI video with MP3 audio
By rijulHKG in forum AudioReplies: 1Last Post: 15th Jul 2007, 00:23 -
Losing audio data converting AC3 to MP3, Help!
By blueprint in forum AudioReplies: 8Last Post: 24th May 2007, 14:55
