I recorder a TV-movie with a hauppauge PVR150. Now I want to author it to DVD with DVDlab. I have done this allready several times without any problem. Normally on the main menu i have 2 button: "play movie" and "chapters".
For this movie I want to make a motion menu. I have 2 movie sequences I want to use as buttons. I dragged the movie twice to the menu and linked it with the movie start and the chapter menu. I also made some menu transitions.
Now I want to make a motion menu. I select both starting points, the length and bitrate. Then I start rendering.
Step 1 (rendering) went well but step 2 (merging object and encoding video frame) doesn't work. It freezes after a couple of frames. I tried it several times and its allways the same.
What can be wrong here? lenght to long? bitrate to low? ...
anyone a suggestion?
Sounds like an error in the video itself. Try re-encoding.
"Hello. My name is Inigo Montoya. You killed my father. Prepare to die." -
Originally Posted by equinox137
Even so, DVD-Lab is very picky about sources that aren't properly prepared. If it detects anything in the video is not up to spec, it will puke, as it has been doing on you. To get the most out of DVD-Lab, you really have to have a stand alone encoder such as TMPGEnc. In my experience, there's really no way around it.
It is the first time i have this problem. I have done this many times before without problems.
Originally Posted by guns1inger -
Originally Posted by andyr74
I'm not saying do that every time, I'm just saying it may fix the problem this time around."Hello. My name is Inigo Montoya. You killed my father. Prepare to die."
DVDlab PRO : Motion menu, cells, missing button highlights !
By TheCap in forum Authoring (DVD)Replies: 18Last Post: 13th Jul 2011, 11:14 -
Music in your DVD Menu's with DvdLab Pro
By RickyPinxt in forum Authoring (DVD)Replies: 5Last Post: 8th Apr 2010, 17:45 -
Motion Menus in DVDLab Pro question
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 1Last Post: 8th Mar 2009, 16:47 -
DVDLab Pro Menu Structure Questions
By raouliii in forum Authoring (DVD)Replies: 1Last Post: 4th Dec 2007, 21:32 -
DVDLab PRO - Music in Menu
By poutniksantiago in forum Authoring (DVD)Replies: 8Last Post: 15th Nov 2007, 07:28
