So is there any way to get around the message at installation that says I can't use Encore becuse my processor doesn't support SSE2 ?
son-of-a!
Why would they make software that way? My cpu isn't great or anything but it can still run programs, it's an AMD 1800+ I was looking forward to learning Encore. -
Does the motherboard accept an upgradable CPU, or is that part of the chipset??
I don't know.. I know the motherboard can take a better chip, but if I were to go that far, I'd just put together a better system anyways... I was hoping there might be some special "hack" or way to trick Encore DVD into thinking my CPU had the right feature supported.
encore dvd adobe cs5
By donnaglait in forum Authoring (DVD)Replies: 2Last Post: 26th Aug 2011, 07:30 -
Adobe Encore DVD Question...
By sdsumike619 in forum Authoring (DVD)Replies: 10Last Post: 26th Aug 2011, 06:46 -
Adobe Encore DVD and subtitles ...
By Liru in forum Authoring (DVD)Replies: 17Last Post: 14th Oct 2010, 17:05 -
Need an Adobe Encore DVD Guru for this one....
By sdsumike619 in forum Authoring (DVD)Replies: 2Last Post: 9th May 2008, 20:24 -
Problem in Adobe Encore DVD
By zombie_chan in forum Authoring (DVD)Replies: 10Last Post: 24th Apr 2008, 01:09
