want to join to divx clips of the same movie,but they both have different audio rates, how to do this virtuAL DUB.
You don't, not unless you reencode one of the audio tracks to match the other.
Take the odd one and in VD under Audio, select 'full processing mode', then 'conversion' and adjust it to match the other file. Under 'Video', select 'Direct stream copy'. Save it with a new filename. Only the audio will be modified.
Then they should append. VD is very particular that appended files match in all ways before appending. Just a decimal point off can cause problems. You can see the information for a video file in 'File>File information'.
Virtual Dub say's No audio decompressor to decompress source audio
By s_joy09 in forum Newbie / General discussionsReplies: 10Last Post: 25th Dec 2011, 14:03 -
Cannot join two clip in Virtual Dub
By s_joy09 in forum Newbie / General discussionsReplies: 2Last Post: 5th Mar 2011, 16:15 -
Question how to directly join 3 clips with Virtual DubMod
By jimdagys in forum EditingReplies: 6Last Post: 5th Jul 2009, 21:42 -
Virtual Dub Audio Not In Sync
By RKelly in forum EditingReplies: 2Last Post: 28th May 2008, 19:45 -
I can't join two avi files with Virtual Dub
By Hopalong Cassidy in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2007, 16:21
