I have a few movies for my daughter, and i always get this error when trying to convert avi to dvd with avi2dvd. [6:22:34 PM] AVI2DVD Started !
[6:22:36 PM] Type mode : Avi Input
[6:22:36 PM] Output : Dvd
[6:22:36 PM] Encoder Selected : FreeEnc
[6:22:36 PM] Start demuxing the AudioStream No.1 ...
[6:23:30 PM] Demuxing of the selected audio finished
successfully ! [C:\Documents and
Settings\Andy\Desktop\Avi2dvd_temp\Extracted_Audio .a
c3 101789440 Bytes]
[6:23:30 PM] Starts Audio correction ...
[6:23:40 PM] Audio Fixed successfully ! [C:\Documents and
Settings\Andy\Desktop\Avi2dvd_temp\Fixed_Audio01.a c3
101785088 Bytes]
[6:23:40 PM] Starts Ac3->Ac3 convertion ...
[6:23:41 PM] Audio converted in Ac3 successfully !
[C:\Documents and
Settings\Andy\Desktop\Avi2dvd_temp\AudioStream 1 AC3
2CH.ac3 101785088 Bytes]
[6:23:41 PM] Start creating avisynth script ...
[6:23:41 PM] Avisynth script created successfully !
[C:\Documents and
Settings\Andy\Desktop\Avi2dvd_temp\Avisynth_Script _Fil
e.avs 199 Bytes]
[6:23:41 PM] Bitrate used : 5499 Kbpps
[6:23:41 PM] Start video encoding ...
[6:23:48 PM] Video encoded successfully ! [C:\Documents
and
Settings\Andy\Desktop\Avi2dvd_temp\Encoded_Video.m
2v -1 Bytes]
[6:23:48 PM] Job NOT Done. There are warnings ... Find at
the log file the 0 byte generated file to focus where exactly
the problem appears
I dont even come close to understanding this but nero always comes up with an error after ruining a blank dvd. If i want to just play the avi on my dvd player(it is capable) do i have to do anything special when burning? Thanks
Your video encoder didn't work / crashed.
That fact that it took only 7 seconds to spit out the video should tell you it's dead. You can try running encoder yourself and feed it the AVISynth script (should still be there) and see if it generates the M2V file. If it does, you can author directly with GUIforDVDAuthor or similar program.[6:23:41 PM] Start creating avisynth script ...
[C:\Documents and
e.avs 199 Bytes]
and
2v -1 Bytes] -
HEy Goomer:Originally Posted by kschang
Why dont you try with another encoder ?? QuEnc or NuEnc ?? they are slower but they have better quality.
If that dont work try to create a new avi file with virtualDub .It worked for me once or twice.
hilario.
How can I fix a "interface not supported" error in avi2dvd?
By Han Solo1 in forum Newbie / General discussionsReplies: 2Last Post: 19th Feb 2009, 14:51 -
error while encoding, someone explain
By arabian in forum SubtitleReplies: 3Last Post: 19th Jan 2008, 07:42 -
Error in Avi2DVD program
By justmenow55 in forum Video ConversionReplies: 2Last Post: 6th Aug 2007, 15:47 -
can someone explain?
By icucmerc in forum Video ConversionReplies: 2Last Post: 4th Aug 2007, 10:57 -
avi2dvd scandata error...
By Crapozo in forum Newbie / General discussionsReplies: 2Last Post: 2nd Jun 2007, 05:33
