Well, I thought I'd finally got the hang of working with dvr-ms files. I've been using VideoRedoPlus - which I HIGHLY recommend - to automatically detect commercials, manually delete them, and then convert the file to MPEG-2. Then I use AutoGK to output a nicely sized XviD avi file.
HOWEVER, now I've run into a problem with some movies I've recorded on premium channels. Any program I use to try and convert the dvr-ms file ends up freezing right as the movie begins. When I right click on the dvr-ms file, the protection category says "NO." So why can't I work with this file? So far this has only happened to me with movies recorded on premium channels. Maybe the movie really is protected but not telling me so?
-Tim
I've tried DVRMSToolbox, Digital Media Converter, VideoReDo Plus, AutoDVRconvert...no luck
Any one with a non working cyberhome dvr-1200 or 1600 will buy your remote
By therd3 in forum Newbie / General discussionsReplies: 0Last Post: 21st Sep 2010, 00:21 -
Pioneer DVR video outputs not working - possible to fix? other options?
By JimmyMcV in forum DVD & Blu-ray RecordersReplies: 2Last Post: 10th May 2010, 23:59 -
svcd2dvd ffmpeg has stopped working adding dvr-ms
By Pooch917 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 1st Mar 2010, 09:00 -
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 19:48 -
Replace Dead Hard Drive From DVR 533HS With Working Hard Drive From DVR 640
By gordo1811 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 12th Dec 2007, 15:58
