i am trying to correct the audio in a video file, it is playing to late, but no matter what number i put in the "preload" box, the video stays the same, the audio does not move from it's place and it doesn't change, can someone tell me, if there is anything to do?,
Hi-
Your audio plays after the video? Then it's not the preload you want to adjust at all, but the audio skew. If it's MP3 audio leave both Preload and Interleave alone. And remember, when adjusting the Audio Skew by milliseconds, 1000 ms=1 second. If it's playing late now, then you want a negative audio skew to make it play earlier. For example, if it plays about half a second too late, fill in -500, save and test. -
wow, thank you sooo much I'm always confused between preload and audio skew, thank you very much it works!
Virtual Dub say's No audio decompressor to decompress source audio
By s_joy09 in forum Newbie / General discussionsReplies: 10Last Post: 25th Dec 2011, 15:03 -
no options in audio compression for virtual dub
By jonbaker in forum AudioReplies: 9Last Post: 14th Feb 2010, 20:00 -
No Video In Virtual Dub, Just Audio
By AllenM in forum EditingReplies: 11Last Post: 3rd Oct 2008, 14:35 -
Virtual Dub Audio Not In Sync
By RKelly in forum EditingReplies: 2Last Post: 28th May 2008, 20:45 -
Audio problems with Plextor M402U and Virtual Dub
By nrsgzz in forum Capturing and VCRReplies: 4Last Post: 6th Sep 2007, 18:27
